CISCO 2921
TristanGude
Can I connect a CISCO 2921 Router to a Wan through one of the gig ports or I need an EHWIC to do this?
19 Replies 19
Native vlan is configured on the trunk connection (so on interfaces of both ends that are on the trunk), for example if you want to change the native vlan form default 1 to 4, you would do so:
Router f0/0 ==== TRUNK ==== Switch f0/5
On Router:
int f0/0.4
 encapsulation dot1Q 4 native
On Switch:
int f0/5
  switchport trunk native vlan 4
Aref
Thank you very much.
Let me know if this is correct. I highly appreciate your help.
Switch-A
Vlan 101
Vlan 1 native
Switch connect to router on gig 0/0
interface gig 0/0.1
encapsulation dot1q 1 native
ip address 172.16.0.1 255.255.255.0
ip nat inside
interface gig 0/0.101
encapsulation gig 0/0.101
encapsulation dot1q 101
ip address 172.16.101.1 255.255.255.0
ip nat inside
Switch-B
Vlan 15
Vlan 1 native
Switch connect to router on gig 0/2
interface gig 0/2.1
ip address 172.16.1.1 255.255.255.0
ip nat inside
interface gig 0/2.15
encapsulation gig 0/0.15
encapsulation dot1q 15
ip address 172.16.15.1 255.255.255.0
ip nat inside
Do g0/0.1 and g0/2.1 belong to the same vlan?, if not you should correct the encapsulation configuration on them.
If you can please post your toplogy with all subnet ip addresses and vlans information.
Aref
a
Hello
I Have My Cisco 2921, And I am Trying to Connect Using USB Serial Port With Putty, And When I am Connect it It Doesn't Show anything in the Putty Screen. Same With Tera.
And when I Removed The Compact Flash and Start IT on, I Found It Connected And Start Reading Information?
So What Is The Issue?
Thank You
