CISCO 2921
TristanGude
Can I connect a CISCO 2921 Router to a Wan through one of the gig ports or I need an EHWIC to do this?
19 Replies 19
ghostinthenet
Level 7
Level 7
You can definitely use one of the GigabitEthernet ports. Using one for WAN and the others for LAN/DMZ functionality is a fairly standard configuration for those routers.
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
Thank you. I cannot get it to work. Do you have any configuration example for the WAN side, that you would like to share? Thank you
Hi Tristan,
If you can, please describe the issue with some more details.
Aref
We just bought two CISCO 2921 for my workplace. I am trying to learn how to set them up. We have been using Netgear for years. Our network has grown and Netgears are not enough anymore.
So I have a lab where I have a Netgear FVX538 connected to the Internet. Netgear LAN configuration is 172.18.0.1 255.255.255.0
I connected the CISCO to one of the LAN ports in the NETGEAR through gig 0/0. See configuration below.
I have connected a LAPTOP to gig 0/1, but it does not get to connect to the Internet. Another laptop, which is connected directly to NETGEAR cannot ping the CISCO Router
Using 2272 out of 262136 bytes
! Last configuration change at 19:30:41 PCT Sun Nov 2 2014
version 15.2
hostname CISCO-2921-Router-Elementary
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 25
clock timezone PCT -8 0
ip cef
no ip dhcp conflict logging
ip dhcp excluded-address 172.18.1.1 172.18.1.99
ip dhcp excluded-address 172.18.2.1 172.18.2.99
ip dhcp excluded-address 172.18.3.1 172.18.3.99
ip dhcp pool 0
 network 172.18.2.0 255.255.255.0
 domain-name elsolacademy.net
 dns-server 172.18.0.228
 default-router 172.18.1.1
 lease 30
no ip domain lookup
ip host Netgear-FVX538 172.18.0.1
ip name-server 172.18.0.228
ip name-server 209.18.47.61
ip name-server 209.18.47.62
no ipv6 cef
crypto pki trustpoint TP-self-signed-969957288
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-969957288
 revocation-check none
 rsakeypair TP-self-signed-969957288
crypto pki certificate chain TP-self-signed-969957288
 certificate self-signed 01 nvram:IOS-Self-Sig#3.cer
license udi pid CISCO2921/K9 sn FGL175310DP
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Internet
 ip address 172.18.1.1 255.255.255.0
 ip helper-address 172.18.0.1
 ip helper-address 24.199.49.77
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 172.18.2.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address 172.18.3.1 255.255.255.0
 duplex auto
 speed auto
router rip
 network 172.18.0.0
ip default-gateway 172.18.0.1
ip forward-protocol nd
no ip http server
ip http secure-server
ip route 172.18.1.0 255.255.255.0 172.18.0.1
ip route 172.18.2.0 255.255.255.0 GigabitEthernet0/0
ip route 172.18.3.0 255.255.255.0 GigabitEthernet0/0
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
 password brilla2012
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password brilla2012
 login
 transport input all
scheduler allocate 20000 1000
end
There are many different ways it could be configured depending on the ISP and te technology being used. Do you have any details on what kind of WAN connection you're using?
version 15.2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool 0
 lease 30
no ip domain lookup
no ipv6 cef
 no ip address
 shutdown
 duplex auto
 speed auto
 duplex auto
 speed auto
 duplex auto
 speed auto
router rip
 network 172.18.0.0
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
 password brilla2012
line 2
 no exec
 stopbits 1
line vty 0 4
 password brilla2012
 login
 transport input all
end
Interface GigabitEthernet0/0 is setup with ip address 172.18.1.1 255.255.255.0, and Netgear has ip address 172.18.0.1 255.255.255.0, they are on different networks, you should correct the ip addresses, in addition the static routes are not appropriate, since those networks 172.18.1.0, 172.18.2.0 and 172.18.3.0 are connected to the Cisco router itself, you don't need them, also you should setup a default static route towards your gateway, it should be the Netgear ip address 172.18.0.1, finally you should ensure that the Netgear router knows how to get back to networks 172.18.2.0 and 172.18.3.0.
Aref
First of all, thank you very much.
Let me see if I understood your answer.
1- Change the gig 0/0 address to 172.18.0.50 255.255.255.0. ?
2- IP routes should be ip route 172.18.2.0 255.255.255.0 172.18.0.1
Is that correct?
You are welcome Tristan.
Correct, g0/0 should be on the same subnet of the Negear, instead the default route should be towards any, example "ip route 0.0.0.0 0.0.0.0 172.18.0.1", and as mentioned before, Negear has to know how to get back to networks 172.18.2.x and 172.18.3.x., another solution would be to apply natting on the Cisco router so the Netgear would see all those networks as 172.18.0.x.
Please let me know if you still unclear.
Aref
Thank you
I have made some progress, but now I cannot route from the vlans.
See attached config
Now the router is directly connected to the Internet, through gig 0/1
gig 0/0 is the internal network
Hi Tristan,
That because the subinterfaces are not able to inter-route with the same physical interface where they are configured. Please try to do these modifications:
 no ip address
 no ip nat inside
interface GigabitEthernet0/0.1
 encapsulation dot1Q 1 (assuming the native vlan on the trunk is vlan 1)
 ip address  172.16.0.1 255.255.255.0
 ip nat inside
Now on all other subinterfaces you should apply "ip nat inside", example:
interface GigabitEthernet0/0.15
 ip nat inside
interface GigabitEthernet0/0.101
 ip nat inside
and so on.
This static route is not needed and is not correct, because with that you are saying to route the traffic towards the network 172.16.0.0/16 out of g0/1 interface. It would not hurt in your case because the router would prefer the connected routes overy the static one, but please remove it:
no ip route 172.16.0.0 255.255.255.0 GigabitEthernet0/1
Aref
Thank you very much
You are very welcome.
Please let me know if it did work properly.
Aref
How can I define the Native Vlan or any other vlan in more than one interface? is that possible?
