Packet capture on switch 4506 E
sainath9890
I have configured to capture the packet on L3 switches
monitor capture BUFFER int Port-channel10 both access-list ACCESS_LIST buffer size 5
I am seeing one way traffic from LAN device to Device in data center. And no opposite traffic from data center in Capture.
Both devices in different network pool.
However I am seeing both way traffic from devices which are in same subset
Device: 4506 E Sup 7L-E
balaji.bandi
look at the below document :
If you see out-of-order packets, it is recommended that you change your configuration from both to in on both interfaces.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4500-series-switches/116470-configure-product-00.html
https://community.cisco.com/t5/networking-documents/4500-wireshark-quick-setup-guide/ta-p/3133452
BB
