Cisco 2951 can't see SM-D-ES3-48-P module.
grinch182
Hello and thanks to anyone who will answer this post. I have the situation with my new Cisco 2951 router. It has only one module on board - SM-D-ES3-48-P. I don't know what is wrong but I can't see any information about this module. When I connect my laptop to any port it's become green, but it's still green even after I disconnect PC from this port. Sh ip int brief command shows only built-in gigabit interfaces. I also connect my second PC to the router by console to monitor any changes when I connect or disconnect laptop to the module's ports. No messages was generated.
there is Sh hardware command output:
Internet#sh hardware
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 03:51 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Internet uptime is 19 minutes
System returned to ROM by reload at 10:10:02 UTC Wed Jan 26 2011
System image file is "flash0:c2951-universalk9-mz.SPA.150-1.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 481280K/43008K bytes of memory.
Processor board ID FHK1445F17G
4 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2951/K9          FHK1445F17G
Technology Package License Information for Module:'c2951'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
uc            None          None          None
data          None          None          None
2 Accepted Solutions
Nagendra Kumar Nainar
SM-D-ES3-48-P is a service module which is a switch that runs its own IOS/process but sits on router slot. Those interfaces will not be listed as part of router. If you want to access it or configre, you can either reverse telent or use "service-module" command as below,
service-module gigabit session
For example, if the module is in slot 2, use the below command,
service-module gigabit 2/0 session
Nagendra
You can probably see the module if you use the command
show inventory raw
I hope it helps
Gonçalo
Nagendra
show inventory raw
I hope it helps
Gonçalo
grinch182
Thank you very much, guys. Now I can configure those interfaces.
