Cisco 2960 Firmware upgrade
PKH1994
I want to upgrade iso from 12.2(53)SE2 to higher version for  WS-C2960-24PC-L model switch.  please anyone tell me which one higher version is better and how to download new version iso??
In https://software.cisco.com/  4 type of file showing 1) LAN BASE & LAN LITE  2)LAN BASE WITH WEB BASED DEV MGR and LITE
which one i should  download or support ???
switch model is attached PFA.
@Takumi Muto @Cisco Engineer
2 Accepted Solutions
Leo Laohoo
The most stable IOS version for the 2960/2960G are 12.2(55)SE or 15.0(2)SE.
Download the TAR file and use the recommended method of updating the firmware:
archive download-sw tftp://<TFTP_IP ADDRESS>/<IOS_FILENAME>.tar
IMPORTANT:  Do not forget to read the Release Notes.
Mark Elsen
 - Use recommended release and or .tar extension if you need GUI access : https://software.cisco.com/download/home/281231715/type/280805680/release/12.2.55-SE12
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
6 Replies 6
Leo Laohoo
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
echaos
ws-c2960x-24ps-l model of ios update 방법을 알고 싶습니다.
Catalyst 2960-Plus 24PC-L Switch
Current Stable recommended version from Cisco
https://software.cisco.com/download/home/284776529/type/280805680/release/15.2.7E11
Release Date = 06-Sep-2024
Note: Don't forget to take backup & also do upgradation in an approved maintenance window.
this is for 2960 plus and this topic is for WS-C2960-24PC-L
Won’t this cause any problems with updates?
No, it won't as long as the firmware is 12.2(55)SE or 15.0(2)SE train.
