Cisco 2960 + High cpu skipes
vinayjaiswal
Level 3
Level 3
Hi Guys,
We are facing intermittent high cpu spikes on Cisco 2960 (2960-48TT-L),  We are unable to find out exact processes which are causing high cpu..
We wanted to configure EEM script to get the exact logs during high cpu.  Can we configure it for Cisco 2960 IOS switch,
#show version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:53 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01900000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
FSTRYONEASW04 uptime is 23 weeks, 1 day, 9 hours, 17 minutes
System restarted at 02:07:28 IST Mon Feb 5 2018
System image file is "flash:c2960-lanbasek9-mz.122-55.SE12.bin"
cisco WS-C2960-48TT-L (PowerPC405) processor (revision E0) with 65536K bytes of memory.
Processor board ID FOC1251X0MU
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:24:51:8D:A6:00
Motherboard assembly number     : 73-10391-05
Power supply part number        : 341-0097-02
Motherboard serial number       : FOC12510P98
Power supply serial number      : DCA122985RP
Model revision number           : E0
Motherboard revision number     : A0
Model number                    : WS-C2960-48TT-L
Top Assembly Part Number        : 800-27222-04
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COM3H00BRC
Hardware Board Revision Number  : 0x02
Switch Ports Model              SW Version            SW Image
*    1 50    WS-C2960-48TT-L    12.2(55)SE12          C2960-LANBASEK9-M
Thanks in adv.
Vijay
Leo Laohoo
Plain 2960 do NOT support EEM.
Leo Laohoo
Thanks Leo, I was expecting reply from you. :)
Vijay
