Cisco 2960 setup no access to internet
jk865
I have bought a 2960 switch to work on as I am studying for my CCNA , Im trying to incoperate it into my home network the diagram goes like this
BT Router > Netgear switch (unmanaged) > Patch pannel > 2960 switch
I have set the default gateway and my pc gets an IP address but no access to the internet, I have also added all ports to VLAN 1
Can anyone help please and thanks
18 Replies 18
M02@rt37
Hello @jk865,
Does the PC ping its Gateway ?
Best regards
Yes
OK @jk865
Does the PC ping 8.8.8.8 ?
If yes, do you have DNS configon PC's IP configuration ?
Best regards
Yes I can ping 8.8.8.8 sucsesfully , no DNS configon set to obtain automatically
You need DNS IP config on your PC @jk865
Best regards
What should it be set to? Thanks
@jk865
Which equipement give the DHCP configuration ? It is this equipement that send also the option DHCP concerning IP of DNS server. It is the BT Router ?
Best regards
The BT Router at the moment is the DHCP provider
Still the same with this config
Try 8.8.8.8 @jk865
Best regards
Same issue
@jk865
Also, your PC is plug on Fa 0/3?
If yes delete the command line "dhcp ..." under that Fa 0/3, do on your PC an ipconfig /renew and see if you receive the DNS IP with from DHCP provider.
Best regards
@jk865
On your screenshot you are not in DHCP mode. Please select "obtain an IP dynamically" and see what the PC receive.
Best regards
Ive tried both,
I just reset everything to try again but same issue, I think the hub is giving out IPv6 addresses and this could be an issue? Fa01 is hub , Fa02 is PC
