Cisco 2960 setup no access to internet
jk865
I have bought a 2960 switch to work on as I am studying for my CCNA , Im trying to incoperate it into my home network the diagram goes like this
BT Router > Netgear switch (unmanaged) > Patch pannel > 2960 switch
I have set the default gateway and my pc gets an IP address but no access to the internet, I have also added all ports to VLAN 1
Can anyone help please and thanks
18 Replies 18
Ok @jk865
On your screenshot you are not in DHCP mode as concerned IPv4. Please select "obtain an IP dynamically" and see what the PC receive.
Best regards
andrewswanson
Level 7
Level 7
I think BT Hubs block 3rd party (non BT) DNS by default - does your PC have DNS hardwired? You can check internet connectivity with "ping 8.8.8.8"
hth
Andy
--> I have set the default gateway and my pc gets an IP address but no access to the internet, I have also added all ports to VLAN 1
What do you mean by 'I have set the default gateway' ? If your PC is set to DHCP, you do not need to manually set anything. Can you post the output of 'ipconfig /all' from your PC ?
I have set the default gateway on the switch , I have attached config and ipconfig/all
