Cisco 2960 switch NAT
Kane Smith
Hi all, I have a Cisco 2960 switch running IOS 15.2(7) E7. I configured NAT overload.
Straight forward config:
interface Vlan150
description INSIDE-LAN
ip address 10.150.0.254 255.255.255.0
ip nat inside
interface Vlan192
description OUTSIDE-LAN
ip address 192.168.0.254 255.255.255.0
ip nat outside
ip access-list standard NAT-LIST
permit 10.150.0.0 0.0.255.255
ip nat inside source list NAT-LIST interface Vlan192 overload
NAT doesn't work when a device on the 10.150.x.x network (default gateway is 10.150.0.254) tries to reach the Internet.
However, if I source a PING from 10.150.0.254, it works fine:
SW1#ping 8.8.8.8 source 10.150.0.254
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.150.0.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/20/25 ms
SW1#
SW1#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 192.168.0.254:1024 10.150.0.254:3 8.8.8.8:3 8.8.8.8:1024
SW1#
I have verified using traceroute that the PC on the 10.150.x.x network is indeed going to SW1 in order to get to 8.8.8.8.
Any ideas please?
2 Accepted Solutions
Hello @Kane Smith ,
you need a router to be able to NAT user traffic.
NAT support on switches start with Cat9300  ( it was supported also on high end Cat6500, Cat6800, these were the first one to support it)
I'm surprised the device accepted the NAT commands, however it is not going  to work with user traffic.
Hope to help
Giuseppe
Hello
That make sense its a lab simulation as on real hardware of 2960s they do NOT support nat
Kind Regards
Paul
19 Replies 19
paul.driver
Hello
Just to confirm if am understanding -  you have a 2960 switch performing NAT - correct?
Kind Regards
Paul
Friend
Just to make you notice your reply is double and one of reply without profile photo' contact manager if you want
MHM
Hello @MHM Cisco World
FYI its  due to having dual cco accounts and flipping between them, as such my browser(s) cannot keep up.
cheers..
Kind Regards
Paul
Yes. That is correct. Its in a lab environment. Does everything we need but NAT. Didn't really want to add a router to perform just one function.
Correct this to be
permit 10.150.0.0 0.0.0.255
Hello @Kane Smith ,
Hope to help
Giuseppe
""I'm surprised the device accepted the NAT commands""
Me To how device accpet command?
MHM
Yep, it accepts the commands and also performs NAT when the traffic is sourced from the switch's own interface:
Here is a NAT debug:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/18/25 ms
SW1#
Sep 27 09:41:08.133: NAT: ICMP id=3->1027
Sep 27 09:41:08.133: NAT: s=10.150.0.254->192.168.0.254, d=8.8.8.8 [15]
Sep 27 09:41:08.150: NAT: ICMP id=1027->3
Sep 27 09:41:08.150: NAT: s=8.8.8.8, d=192.168.0.254->10.150.0.254 [0]
Sep 27 09:41:08.159: NAT: ICMP id=3->1027
Sep 27 09:41:08.159: NAT: s=10.150.0.254->192.168.0.254, d=8.8.8.8 [16]
Sep 27 09:41:08.175: NAT: ICMP id=1027->3
Sep 27 09:41:08.175: NAT: s=8.8.8.8, d=192.168.0.254->10.150.0.254 [0]
Sep 27 09:41:08.175: NAT: ICMP id=3->1027
Sep 27 09:41:08.175: NAT: s=10.150.0.254->192.168.0.254, d=8.8.8.8 [17]
Sep 27 09:41:08.192: NAT: ICMP id=1027->3
Sep 27 09:41:08.192: NAT: s=8.8.8.8, d=192.168.0.254->10.150.0.254 [0]
SW1#
Sep 27 09:41:08.192: NAT: ICMP id=3->1027
Sep 27 09:41:08.192: NAT: s=10.150.0.254->192.168.0.254, d=8.8.8.8 [18]
Sep 27 09:41:08.217: NAT: ICMP id=1027->3
Sep 27 09:41:08.217: NAT: s=8.8.8.8, d=192.168.0.254->10.150.0.254 [0]
Sep 27 09:41:08.217: NAT: ICMP id=3->1027
Sep 27 09:41:08.217: NAT: s=10.150.0.254->192.168.0.254, d=8.8.8.8 [19]
Sep 27 09:41:08.234: NAT: ICMP id=1027->3
Sep 27 09:41:08.234: NAT: s=8.8.8.8, d=192.168.0.254->10.150.0.254 [0]
SW1#
Then friend
Did you check routing
Are you uave defualt route toward  Vlan192?
Are you run
Ip routing
In SW
MHM
Yes I have a default route towards VLAN 192. That's how the ping to 8.8.8.8 works.
And ypu run
Ip routing?
If yes
Try use debug NAT and ping let see if SW show any NAT log
MHM
with SW or router you need to correct your ACL
MHM
Good spot. I updated the ACL as you stated to a /24 wildcard mask but there is still no change.
