Cisco 2960 switch NAT
Kane Smith
Hi all, I have a Cisco 2960 switch running IOS 15.2(7) E7. I configured NAT overload.
Straight forward config:
interface Vlan150
description INSIDE-LAN
ip address 10.150.0.254 255.255.255.0
ip nat inside
interface Vlan192
description OUTSIDE-LAN
ip address 192.168.0.254 255.255.255.0
ip nat outside
ip access-list standard NAT-LIST
permit 10.150.0.0 0.0.255.255
ip nat inside source list NAT-LIST interface Vlan192 overload
NAT doesn't work when a device on the 10.150.x.x network (default gateway is 10.150.0.254) tries to reach the Internet.
However, if I source a PING from 10.150.0.254, it works fine:
SW1#ping 8.8.8.8 source 10.150.0.254
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.150.0.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/20/25 ms
SW1#
SW1#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 192.168.0.254:1024 10.150.0.254:3 8.8.8.8:3 8.8.8.8:1024
SW1#
I have verified using traceroute that the PC on the 10.150.x.x network is indeed going to SW1 in order to get to 8.8.8.8.
Any ideas please?
19 Replies 19
You need to use /24 but
As other answer you' not all SW support NAT
Change the platform to router and run same NAT
Note:- if you use router I dont think it support vlan SVI so you need to use router port
MHM
So I really need a small lab device with these features:
- Small switch 8 or 12 ports (to remove the fan noise)
- Gig Ethernet ports
- PoE
- dot1x
- NAT
- IOS 15
My little 2960 does all of the above except NAT.
Friend I answer you above check it'
MHM
Hello
That make sense its a lab simulation as on real hardware of 2960s they do NOT support nat
Kind Regards
Paul
Friend @Kane Smith
I Check many times these SW don't support NAT as @paul driver @Giuseppe Larosa  mention
And what we see traffic generate from device itself is NAT it can bug in software you use for emulated.
So don't waste your time
Use router Instead of SW and run NAT
MHM
