Cisco 3550: Data bus test failed for associated data
nimalrajphilips
Hello Guys, I have Cisco 3550 switch. When i switch it on, i can login to the global configuration mode. But i cant view any interfaces. I am getting a message saying "data bus test failed for associated data". Is this is reolvable? Or is it is a hardware issue?
I have attached the show run and show version output below.
Switch>
Switch>en
Switch#sh run
Building configuration...
Current configuration : 332 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
interface Vlan1
no ip address
shutdown
ip classless
ip http server
line con 0
line vty 5 15
end
Switch#
Switch#
Switch#sh ver
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(13)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 25-Mar-03 23:21 by yenanh
Image text-base: 0x00003000, data-base: 0x00654C9C
ROM: Bootstrap program is C3550 boot loader
Switch uptime is 35 minutes
System image file is "flash:c3550-i9q3l2-mz.121-13.EA1a/c3550-i9q3l2-mz.121-13.EA1a.bin"
cisco WS-C3550-24 (PowerPC) processor (revision J0) with 65526K/8192K bytes of memory.
Processor board ID CAT0725X33L
Last reset from warm-reset
Running Layer2/3 Switching Image
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0D:29:9E:9B:00
Motherboard assembly number: 73-5700-10
Power supply part number: 34-0966-02
Motherboard serial number: CAT072503JX
Power supply serial number: DTH072305BG
Model revision number: J0
Motherboard revision number: A0
Model number: WS-C3550-24-SMI
System serial number: CAT0725X33L
Configuration register is 0x10F
!!! WARNING: The switch is not usable !!!
Reason:
Switch#
Switch#
BR
Nimalraj
paolo bevilacqua
As the message clearly states, the switch is not useable, and must be replaced.
Is it is possible to figure out what is the problem and any means of rectifying it..??
It is not possible to rectify the problem, and the unit must be replaced.
Calin C.
Level 5
Level 5
Sometime ago, I've seen this error and the device was hardware fault, as far as I remember.
Calin
