CISCO 3560 - Supervisor-3 - Fatal messages
dukeminus
Yesterday I started recieving the following errors on my 3560 switch:
Jul 23 14:19:16.933 UTC: %SUPERVISOR-3-FATAL: MIC exception error 80 180C0080 91 0
-Traceback= 651638 6547E0 5C9CB0 5C9C58 5CB8F4 5CBC6C 5C9D60 8051AC
Jul 23 14:19:16.933 UTC: %SUPERVISOR-3-FATAL: MIC exception error 80 190C0080 0 0
-Traceback= 651638 6547E0 5C9CB0 5C9C58 5CB8F4 5CBC6C 5C9D60 8053F8
Jul 23 14:19:16.933 UTC: %SUPERVISOR-3-FATAL: MIC exception error 80 1E0C0080 75 0
Kelvin Willacey
Level 4
Level 4
That seems like something for TAC. Here is what I found:
SUPERVISOR Messages
Error Message    SUPERVISOR-3-FATAL: [chars].
Note This message applies only to Catalyst 3750, 3560, 2975, 2970, and 2960 switches.
Explanation    An internal error occurred in the supervisor ASIC. [chars] is the detailed error message.
Recommended Action    Copy the message exactly as it appears on the console or in the system log.  Research and attempt to resolve the error by using the Output Interpreter. Use the Bug Toolkit to  look for similar reported problems. If you still require assistance, open a case with the TAC, or  contact your Cisco technical support representative, and provide the representative with the  gathered information. For more information about these online tools and about contacting Cisco, see the  "Error Message Traceback Reports" section.
Thanks for sharing this info
marce1000
 - Here are some bug reports which might be related :
              https://bst.cloudapps.cisco.com/bugsearch/search?kw=SUPERVISOR-3-FATAL%203560&pf=prdNm&sb=anfr
 M.
