Cisco 3945 Router not detecting VWIC3-2MFT-T1/E1 Voice Card
edwardwaithaka
We have installed a VWIC3-2MFT card on a Cisco 3945 voice gateway but the router doesnt detect the card. out put is as below;
What could be the issue?
Router Version
System image file is "flash0:c3900-universalk9-mz.SPA.150-1.M.bin"
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 980992K/67584K bytes of memory.
Processor board ID FCZ135070YF
2 FastEthernet interfaces
3 Gigabit Ethernet interfaces
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
Device#     PID              SN
*0       C3900-SPE150/K9       FOCxxxxxxJJ
Technology Package License Information for Module:'c3900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
uc            uck9          Permanent     uck9
data          None          None          None
"show diag" output
WIC Slot 1:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision        : 1.0
Top Assy. Part Number    : 800-34658-01
Part Number              : 73-13420-01
Board Revision           : B0
Deviation Number         : 0
Fab Version              : 05
PCB Serial Number        : FOC16323KSC
Version Identifier       : V01
Product (FRU) Number     : VWIC3-2MFT-T1/E1
3 Accepted Solutions
Raju Sekharan
paolo bevilacqua
Have you inserted the card with router turned off ?
You also need to update IOS.
8 Replies 8
    Please post "show inventory".
Rgds,
Toshi
------------------ show inventory ------------------
NAME: "CISCO3945-CHASSIS", DESCR: "CISCO3945-CHASSIS"
PID: CISCO3945-CHASSIS , VID: V01 , SN:
NAME: "Cisco Services Performance Engine 150 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 150 for Cisco 3900 ISR"
PID: C3900-SPE150/K9   , VID: V01 , SN:
NAME: "Two-Port Fast Ethernet High Speed WAN Interface Card on Slot 0 SubSlot 0", DESCR: "Two-Port Fast Ethernet High Speed WAN Interface Card"
PID: HWIC-2FE          , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN:
NAME: "C3900 AC Power Supply 2", DESCR: "C3900 AC Power Supply 2"
PID: PWR-3900-AC       , VID: V03 , SN:
Raju Sekharan
VWIC3-2MFT-T1/E1 requires minimum IOS version 15.0(1)M3,
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/data_sheet_c36-609138.html
Raju
    Okay You've got PVDM. Now you need to check IOS.
Here you go : http://www.cisco.com/en/US/prod/collateral/routers/ps5855/data_sheet_c36-609138.html
HTH,
Toshi
I will schedule an upgrade and see if it helps. Thank you.
paolo bevilacqua
edwardwaithaka
Upgrade of IOS resolved the issue.
Sent from Cisco Technical Support Android App
Very good.Thank you for the nice rating and good luck!
