Cisco 4321 issues DNS and Internet connection?
scottastafford5
I'm having issues connecting ISR 4321, i can't access the internet at all. I can ping the ISP on the router but i can't ping 8.8.8.8 and when connected i don't get default gateway on laptop and only get ip address. Below is current configuration on the router.
Building configuration...
Current configuration : 3046 bytes
! Last configuration change at 23:52:43 UTC Sun Sep 30 2018
version 15.4
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip name-server 8.8.8.8
ip dhcp pool Planet
network 192.168.1.0 255.255.255.0
subscriber templating
domain lookup
redundancy
mode none
interface GigabitEthernet0/0/0
ip nat inside
negotiation auto
interface GigabitEthernet0/0/1
ip address dhcp
ip nat outside
negotiation auto
vrf forwarding Mgmt-intf
no ip address
negotiation auto
router rip
version 2
network 192.168.1.0
no auto-summary
ip default-gateway 192.168.1.1
ip nat inside source list 50 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
access-list 50 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
8 Replies 8
Eric101
Looking at your configs very briefly, I assume Gi0/0/1 is your ISP connection.
Your static IP routes are pointing out the wrong interface. It should be gi0/0/1
I agree with the suggestion that your static default routes are pointing at the wrong interface. But I believe that this is not the only issue with your static default routes. As configured both of them include reference to what should be the outbound interface (if you correct which interface you point at).
But when a static route points at an outbound interface without specifying the next hop (especially if the interface is Ethernet) then IOS assumes that the destination addresses are locally connected and will arp for each destination address.
My suggestion is to remove the first static default route which specifies only the interface and to modify the second static default route to remove the reference to the interface. So you would have
ip route 0.0.0.0 0.0.0.0 dhcp
Rick
Rick
The route was configured on the inside nat interface so it would not work and Richard's suggestion is the correct solution because it takes the interface off of the command.
Duplicate post - with this
Kind Regards
Paul
I have working configuration but i'm not sure if my phone is jacked up or the its router. I use app called speedtest.net and i should be getting 75/75 and on my laptop i'm getting about 50/50 but phone is 70/5 which is odd. I also found out that if i turn off the Cisco router i lose my configuration, is that correct.
Current configuration : 1383 bytes
! Last configuration change at 21:00:28 UTC Mon Oct 1 2018
version 15.4
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip dhcp pool Planet
import all
default-router 192.168.1.1
dns-server 192.168.1.1
lease 0 12
ip dhcp pool planet
redundancy
mode none
ip nat inside
negotiation auto
ip address dhcp
ip nat outside
negotiation auto
no ip address
negotiation auto
ip nat inside source list 50 interface GigabitEthernet0/0/1 overload
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/1 dhcp
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
You tell us that " i'm not sure if my phone is jacked up or the its router". But you give us very little detail to work with to find answers to that. Is the app speediest run on the phone? How does the phone connect in this environment?
As far as losing the configuration if you turn off the router, this is not normal. It suggests that the config register may not be set correctly. Please post the output of show version which is the best way to check the setting of the config register.
The original post was about the fact that you did not have access to Internet. Now it appears that this is resolved and now the question is not access but is performance. This is good progress. I notice that your static default route still points to Gig0/0/1. I suggest that you remove this parameter so that the static default route specifies only DHCP. Try this and let us know if performance changes.
Rick
Rick
Sorry i thought i attached the config file, the phone is connect through
wifi using ap access point. I appreciate all the advice i'm getting.
version 15.4
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip dhcp pool Planet
import all
lease 0 12
ip dhcp pool planet
license udi pid ISR4321/K9 sn FDO2036170Z
redundancy
mode none
ip nat inside
negotiation auto
ip address dhcp
ip nat outside
negotiation auto
no ip address
negotiation auto
no ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
I have looked through the config that you posted and other than the change that I have suggested in the static default route I do not see any issues in the config that seem to relate to the symptoms that you describe. It is obvious that you have some kind of switch attached to Gig0/0/0, with ap and other devices connected through that switch. If you are seeing performance differences between several connected devices I might look at the possibility that something in the switch or in the ap is affecting the traffic.
As far as losing the configuration when you turn off the router I asked that you post the output of show version. Please post that.
Rick
Rick
