CISCO 4321 suddenly not generating ip from POOL
FIPD
Greeting!  After the power outage our router started not giving out IP addresses from a List of Pools. im puzzled bcoz setting used to work fine.
ip dhcp excluded-address 192.168.2.1 192.168.2.30
ip dhcp excluded-address 192.168.10.1 192.168.10.100
ip dhcp excluded-address 192.168.20.1 192.168.20.100
ip dhcp excluded-address 192.168.30.1 192.168.30.30
ip dhcp pool MAS
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
domain-name MASr9
dns-server 192.168.10.98 1.1.1.3
ip dhcp pool vlan10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool vlan20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool vlan30
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
subscriber templating
license udi pid ISR4321/K9 sn FDO21330XTK
redundancy
mode none
vlan internal allocation policy ascending
class-map type inspect match-all 587
match access-group name smtps
interface GigabitEthernet0/0/0
no ip address
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1
ip address 10.10.10.2 255.255.255.252
negotiation auto
interface GigabitEthernet0/2/0
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/2/1
switchport access vlan 20
interface GigabitEthernet0/2/2
switchport access vlan 30
interface GigabitEthernet0/2/3
switchport access vlan 100
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip helper-address 192.168.10.1
ip nat inside
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip helper-address 192.168.20.1
ip nat inside
interface Vlan30
ip address 192.168.30.1 255.255.255.0
ip helper-address 192.168.30.1
ip nat inside
interface Vlan100
ip address 192.168.2.1 255.255.255.0
ip helper-address 192.168.2.1
ip nat inside
interface Dialer2
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname PGN
ppp chap password 0
router eigrp 10
network 10.10.10.0 0.0.0.3
network 192.168.1.0
network 192.168.2.0
ip nat inside source static tcp 192.168.2.11 3389 x.x.x.x 3389 extendable
ip nat inside source static tcp 192.168.2.14 8000 x.x.x.x 8000 extendable
ip nat inside source list 101 interface Dialer2 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 Dialer2
15 Replies 15
I see it in config you share but I think it old config
anyway
glad your issue is solved
you are so so welcome
have a nice summer
MHM
