CISCO 4321 suddenly not generating ip from POOL
FIPD
Greeting!  After the power outage our router started not giving out IP addresses from a List of Pools. im puzzled bcoz setting used to work fine.
ip dhcp excluded-address 192.168.2.1 192.168.2.30
ip dhcp excluded-address 192.168.10.1 192.168.10.100
ip dhcp excluded-address 192.168.20.1 192.168.20.100
ip dhcp excluded-address 192.168.30.1 192.168.30.30
ip dhcp pool MAS
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
domain-name MASr9
dns-server 192.168.10.98 1.1.1.3
ip dhcp pool vlan10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool vlan20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool vlan30
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
subscriber templating
license udi pid ISR4321/K9 sn FDO21330XTK
redundancy
mode none
vlan internal allocation policy ascending
class-map type inspect match-all 587
match access-group name smtps
interface GigabitEthernet0/0/0
no ip address
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1
ip address 10.10.10.2 255.255.255.252
negotiation auto
interface GigabitEthernet0/2/0
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/2/1
switchport access vlan 20
interface GigabitEthernet0/2/2
switchport access vlan 30
interface GigabitEthernet0/2/3
switchport access vlan 100
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip helper-address 192.168.10.1
ip nat inside
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip helper-address 192.168.20.1
ip nat inside
interface Vlan30
ip address 192.168.30.1 255.255.255.0
ip helper-address 192.168.30.1
ip nat inside
interface Vlan100
ip address 192.168.2.1 255.255.255.0
ip helper-address 192.168.2.1
ip nat inside
interface Dialer2
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname PGN
ppp chap password 0
router eigrp 10
network 10.10.10.0 0.0.0.3
network 192.168.1.0
network 192.168.2.0
ip nat inside source static tcp 192.168.2.11 3389 x.x.x.x 3389 extendable
ip nat inside source static tcp 192.168.2.14 8000 x.x.x.x 8000 extendable
ip nat inside source list 101 interface Dialer2 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 Dialer2
15 Replies 15
Share
Show ip dhcp pool
Show ip dhcp statistics
MHM
 these are the results..
run
debug dhcp server
and
sorry I dont see
show ip dhcp statistics
MHM
 all at zero..
there is no Packet at all all counter is zero
can you share the router and Sw config let me check it in lab
MHM
If you do show log are there any messages that relate to DHCP?
I am interested in this statement "i can configure the PC with static ip but cant ping the gateway" This suggests that there may be a basic connectivity issue. Can you post the output of these commands on the router:
show ip interface brief
show arp
I notice in the router config that you are specifying helper address
interface Vlan10
While I am not sure that it is a problem it is certainly not needed. I suggest that you remove the helper address commands on the router.
I see in the router config what appear to be 4 switch ports configured as access ports
Can you tell us what is connected on these ports?
I am a bit puzzled about the fact that there are 4 vlan interfaces with IP addresses on the router and 4 SVIs with IP addresses on the switch. Is there a reason for this?
Can you tell us how the switch is connected to the router?
Rick
try and stop/start the DHCP service:
4321(config)#no service dhcp
4321(config)#service dhcp
No go, tried no service dhcp then reload then sevice dhcp ..
balaji.bandi
This was not clear where the clients connected and not able to get IP address - is the client connected same device ?
or is the clients connected to switch ? if that is switch, what port that is connected on the router ?
Can you configure static IP to PC in that range and able to ping gateway and able to get internet ?
Also you have ACL 101 - i do not see anything matching ?
BB
router - switch-devices
clients are connected to a switch, router has a NIM that has 4 switch ports and here the switch is connected.
the ACL 101 is only for giving internet access to the enrolled ip, i failed to copy the entire setting
access-list 101 permit ip host 192.168.20.20 any
what port that switch connected on the router ? can you post switch configuration.? (is the switch acting layer2 ?)
as i see some of the config on router, as below is the any chance connected to switch.
negotiation auto
 can you post below command output
show cdp neigh from switch and router.
show run from switch
show ip interface brief from switch and router.
BB
spanning-tree mode rapid-pvst
diagnostic bootup level minimal
interface GigabitEthernet0/1
switchport trunk allowed vlan 10
switchport trunk native vlan 10
switchport mode trunk
ip dhcp snooping trust
switchport trunk allowed vlan 20
switchport trunk native vlan 20
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
switchport trunk allowed vlan 30
switchport trunk native vlan 30
interface GigabitEthernet0/14
switchport trunk allowed vlan 100
switchport trunk native vlan 100
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
no ip route-cache
interface Vlan10
ip address 192.168.10.2 255.255.255.0
no ip route-cache
interface Vlan20
ip address 192.168.20.2 255.255.255.0
no ip route-cache
interface Vlan30
ip address 192.168.30.2 255.255.255.0
no ip route-cache
interface Vlan100
ip address 192.168.2.2 255.255.255.0
no ip route-cache
ip http server
Unfortunately i don't have right information to guide you  - let me repost my question here and if you can able to answer them to understand how you connected Router and Switch is very important - since you have access port on router and you have trunk config on other side in different ports - it was not clear here.
If the switch is layer then you do not so many SVI on the switch.
negotiation auto
BB
FIPD
thank you everyone for the help,  i found the culprit. somewhat the command 'ip dhcp snooping trust' was not present inside my config which was there before the outage, but this fix my issue since i was using DHCP snooping on my router and switches. thank you again for the support. the community is really nice and really supportive
