06-22-2024 04:57 AM
I cannot authenticate my CPE on my LNS. The L2TP tunnel seems to work.
interface Dialer0
ip address negociated
encapsulation ppp
dialer-group 1
ppp authentication chap callin
ppp chap hostname test@cisco.lab
ppp chap password 0 test123
endConfig of LNS :
aaa group server radius freeradius
server-private 10.0.1.100 auth-port 1812 acct-port 1813 key 7 XXXXXXXXXXX
ip radius source-interface Loopback0
aaa authentication ppp ppp-radius group freeradius
aaa authorization network network-radius group freeradius
aaa accounting delay-start
aaa accounting update newinfo
aaa accounting network default start-stop group freeradius
aaa session-id common
aaa policy interface-config allow-subinterface
subscriber templating
vpdn enable
vpdn-group VPDN2
description LNS VPDN2
accept-dialin
protocol l2tp
virtual-template 2
source-ip 10.0.1.2
local name LNS-10.0.1.2
lcp renegotiation always
no l2tp tunnel authentication
ip mtu adjust
bba-group pppoe global
virtual-template 2
interface Virtual-Template2
ip unnumbered Loopback100
no ip redirects
no ip proxy-arp
ip verify unicast source reachable-via rx
ppp mtu adaptive
ppp mru match
ppp authentication chap pap ppp-radius
ppp authorization network-radius
ppp multilink
ppp multilink fragment disable
Here is the error I get (LNS) :
.Jun 22 11:39:50.693: ppp206 LCP: O CONFREQ [REQsent] id 5 len 34
.Jun 22 11:39:50.693: ppp206 LCP: AuthProto CHAP (0x0305C22305)
.Jun 22 11:39:50.693: ppp206 LCP: MagicNumber 0x45BC4C4D (0x050645BC4C4D)
.Jun 22 11:39:50.693: ppp206 LCP: MRRU 1524 (0x110405F4)
.Jun 22 11:39:50.693: ppp206 LCP: EndpointDisc 1 cisco-01 (0x130F016C6E732D544C5333312D3031)
.Jun 22 11:39:50.693: ppp206 LCP: Event[Timeout+] State[REQsent to REQsent]
.Jun 22 11:39:52.709: ppp206 LCP: O CONFREQ [REQsent] id 6 len 34
.Jun 22 11:39:52.709: ppp206 LCP: AuthProto CHAP (0x0305C22305)
.Jun 22 11:39:52.709: ppp206 LCP: MagicNumber 0x45BC4C4D (0x050645BC4C4D)
.Jun 22 11:39:52.709: ppp206 LCP: MRRU 1524 (0x110405F4)
.Jun 22 11:39:52.709: ppp206 LCP: EndpointDisc 1 cisco-01 (0x130F016C6E732D544C5333312D3031)
.Jun 22 11:39:52.709: ppp206 LCP: Event[Timeout+] State[REQsent to REQsent]
.Jun 22 11:39:54.724: ppp206 LCP: O CONFREQ [REQsent] id 7 len 34
.Jun 22 11:39:54.724: ppp206 LCP: AuthProto CHAP (0x0305C22305)
.Jun 22 11:39:54.725: ppp206 LCP: MagicNumber 0x45BC4C4D (0x050645BC4C4D)
.Jun 22 11:39:54.725: ppp206 LCP: MRRU 1524 (0x110405F4)
.Jun 22 11:39:54.725: ppp206 LCP: EndpointDisc 1 cisco-01 (0x130F016C6E732D544C5333312D3031)
.Jun 22 11:39:54.725: ppp206 LCP: Event[Timeout+] State[REQsent to REQsent]
.Jun 22 11:39:56.741: ppp206 LCP: O CONFREQ [REQsent] id 8 len 34
.Jun 22 11:39:56.741: ppp206 LCP: AuthProto CHAP (0x0305C22305)
.Jun 22 11:39:56.741: ppp206 LCP: MagicNumber 0x45BC4C4D (0x050645BC4C4D)
.Jun 22 11:39:56.741: ppp206 LCP: MRRU 1524 (0x110405F4)
.Jun 22 11:39:56.741: ppp206 LCP: EndpointDisc 1 cisco-01 (0x130F016C6E732D544C5333312D3031)
.Jun 22 11:39:56.741: ppp206 LCP: Event[Timeout+] State[REQsent to REQsent]
.Jun 22 11:39:58.757: ppp206 LCP: O CONFREQ [REQsent] id 9 len 34
.Jun 22 11:39:58.757: ppp206 LCP: AuthProto CHAP (0x0305C22305)
.Jun 22 11:39:58.757: ppp206 LCP: MagicNumber 0x45BC4C4D (0x050645BC4C4D)
.Jun 22 11:39:58.757: ppp206 LCP: MRRU 1524 (0x110405F4)
.Jun 22 11:39:58.757: ppp206 LCP: EndpointDisc 1 cisco-01 (0x130F016C6E732D544C5333312D3031)
.Jun 22 11:39:58.758: ppp206 LCP: Event[Timeout+] State[REQsent to REQsent]
.Jun 22 11:40:00.773: ppp206 LCP: O CONFREQ [REQsent] id 10 len 34
.Jun 22 11:40:00.773: ppp206 LCP: AuthProto CHAP (0x0305C22305)
.Jun 22 11:40:00.773: ppp206 LCP: MagicNumber 0x45BC4C4D (0x050645BC4C4D)
.Jun 22 11:40:00.773: ppp206 LCP: MRRU 1524 (0x110405F4)
.Jun 22 11:40:00.773: ppp206 LCP: EndpointDisc 1 cisco-01 (0x130F016C6E732D544C5333312D3031)
.Jun 22 11:40:00.773: ppp206 LCP: Event[Timeout+] State[REQsent to REQsent]
.Jun 22 11:40:02.789: ppp206 PPP DISC: LCP failed to negotiate
.Jun 22 11:40:02.789: ppp206 PPP: Sending Acct Event[Down] id[C5EED]
.Jun 22 11:40:02.789: PPP: NET STOP send to AAA.
.Jun 22 11:40:02.789: ppp206 LCP: Event[Timeout-] State[REQsent to Stopped]
.Jun 22 11:40:02.789: ppp206 LCP: Event[DOWN] State[Stopped to Starting]
.Jun 22 11:40:02.789: ppp206 PPP: Phase is DOWN
.Jun 22 11:40:03.468: PPP: Alloc Context [7F41F9B063E8]
.Jun 22 11:40:03.468: ppp207 PPP: Phase is ESTABLISHING
.Jun 22 11:40:03.468: ppp207 LCP: Event[OPEN] State[Initial to Starting]
.Jun 22 11:40:03.469: ppp207 LCP: O CONFREQ [Starting] id 1 len 34I'm stuck, any ideas ?
THANKS.
06-22-2024 09:32 AM
Can I see full config of CEP
MHM
06-22-2024 02:28 PM
I don't have any other configuration to give for the LNS and CPE... It's just missing the loopback but nothing important !
06-22-2024 02:37 PM - edited 06-22-2024 02:46 PM
There is l2tp between lns and lac
And there is pppoe between cpe and lns
As I see you missing some command in cpe for pppoe
That make your config not success
below link for command missing
MHM
06-23-2024 11:58 PM - edited 06-24-2024 12:03 AM
Here I am authenticating a Dialer (Cellular SIM) on an LTE network.
Here is the callflow for how this authentication works :
1 => Radius LTE queries Radius Customer to obtain the end of the LNS tunnel.
2 => LNS Customer queries Radius Customer to retrieve the IP to be sent to the SIM card (Dialer).
06-24-2024 01:09 AM
Sorry
I am busy now
hope other can help you
Goodluck
MHM
06-24-2024 03:41 AM
Hello @sebastien3 ,
your debug shows only outobound packets
there is nothing coming back.
Probably there is something missing in your configuration and this is not a simple setup.
Hope to help
Giuseppe
