Cisco 4331 Boost License
Ruelb2214
Hello All,
We want to try the temporary boost license on our 4331 ISR, we manage to install it and its shows in the summary.
But this command "platform hardware throughput level boost" does not show up after reboot. it's been mentioned in that you do not need smart license to use it. Any one has experience with this command?
Cisco IOS XE Software, Version 16.09.08
System Bootstrap, Version 16.7(5r), RELEASE SOFTWARE
Copyright (c) 1994-2019 by cisco Systems, Inc.
Feature name Enforcement Evaluation Subscription Enabled RightToUse
appxk9 yes yes no no yes
uck9 yes yes no no yes
securityk9 yes yes no no yes
ipbasek9 no no no yes no
FoundationSuiteK9 yes yes no no yes
AdvUCSuiteK9 yes yes no no yes
cme-srst yes yes no no yes
hseck9 yes no no no no
throughput yes yes no yes yes
internal_service yes no no no no
booster_performance yes no no no no
Index 11 Feature: booster_performance
Period left: 12 weeks 6 days
Period Used: 0 minute 0 second
License Type: Evaluation
License State: Active, Not in Use, EULA accepted
License Count: Non-Counted
License Priority: Low
5 Replies 5
marce1000
 - Some of these bug reports might be applicable :
        https://bst.cloudapps.cisco.com/bugsearch?pf=prdNm&kw=platform%20hardware%20throughput%20level%20boost&bt=custV&sb=anfr
 M.
Hi @marce1000 do you have specific bug ID?
Richard Pidcock
Not sure if this is specific to your situation @Ruelb2214 , but check this one out.
CSCvn07416 : Bug Search Tool (cisco.com)
Richard W. Pidcock
Thanks @Richard Pidcock I will check if we hit this bug and update this post.
Ruelb2214
as per TAC this is the bug ID CSCvn03222 : Bug Search Tool (cisco.com)
