08-27-2020 12:29 AM
I recently tested a 4331 with an onboard boost license expecting the 2Gb throughput as per documentation. On boot up i noticed this line below. I confirmed the throughput level is set to boost and the license is active and In-Use
*Aug 26 14:51:12.696: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps
Router#sh platform hardware throughput level
The current throughput level is unthrottled
IOS version is 16.9.5
I tested on Iperf sending traffic bidirectional and sure enough traffic was approx 900Mb one direction and approx 550Mb the other direction.
Is there anyway to remove this restriction?
08-27-2020 12:47 AM
Hello Brian,
there used to be the command:
ISR4311(config)#patform hardware throughput level
If that is still available, what opions are there after 'level' ?
08-27-2020 12:53 AM
Hi Georg,
The boost license came loaded and is enabled in the license and the config as below. I can't see any documentation referring to this 1.47Gbps limit.
Router(config)#platform hardware throughput level ?
100000 throughput in kbps
300000 throughput in kbps
boost Enables unthrottled throughput traffic
Router#sh run | i platform
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform hardware throughput level boost
Index 11 Feature: booster_performance
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
08-27-2020 01:15 AM
odd indeed. Can you use the command and configure a lower value, reboot the router, than change it back to 'level boost' and reboot the router again ?
08-27-2020 03:42 AM
Can you post - show version (complete output)
08-27-2020 08:06 AM
Hi Balaji
As Below,
Georg tried your suggestion as well to reset back to 100000 and then then re-enabling to Boost. Still getting this output on boot:
*Aug 27 14:41:26.989: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps
Router#sh version
Cisco IOS XE Software, Version 16.09.05
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 30-Jan-20 18:53 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 21 minutes
Uptime for this control processor is 23 minutes
System returned to ROM by Reload Command
System image file is "bootflash:isr4300-universalk9.16.09.05.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
Smart Licensing Status: Smart Licensing is DISABLED
cisco ISR4331/K9 (1RU) processor with 1784246K/6147K bytes of memory.
Processor board ID
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
08-27-2020 08:16 AM
since you are running 16.9.5, the problem might be smart licensing, which I think is obligatory since 16.9.1. Try and enable that:
