Cisco 4331 IOS Upgrade 03.16.04 to 16.09.06
johnlloyd_13
Level 9
Level 9
hi,
i need to upgrade my 4331 ISR from 03.16.04 to 16.09.06.
is there a upgrade path to follow? or do i just FTP and set the boot variable directly to the new 16.09.06?
is it required to upgrade rommon to 16.9(1r)? i checked the current rommon code (minimum - 16.7(3r)) is compatible with the target 16.9.6 code per compatibility matrix below:
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/xe-16-12/isr4400swcfg-xe-16-12-book/installing_the_software.html#Cisco_Concept.dita_8829af23-df9e-4314-89d3-ab7e5a4e243a
#sh ver
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
#sh platform
Chassis type: ISR4331/K9
Slot Type State Insert time (ago)
0 ISR4331/K9 ok 3w1d
0/0 ISR4331-3x1GE ok 3w1d
0/4 PVDM4-32 ok 3w1d
1 ISR4331/K9 ok 3w1d
R0 ISR4331/K9 ok, active 3w1d
F0 ISR4331/K9 ok, active 3w1d
P0 PWR-4330-AC ok 3w1d
P2 ACS-4330-FANASSY ok 3w1d
Slot CPLD Version Firmware Version
0 19040541 16.7(3r)
1 19040541 16.7(3r)
R0 19040541 16.7(3r)
F0 19040541 16.7(3r)
5 Replies 5
Leo Laohoo
ROMMON upgrade is mandatory before upgrading to 16.X.X.
NOTE:  Consider upgrading using "Install Mode".
hi leo,
do you have a cisco link for this procedure?
why is there a "minimum" rommon if it's mandatory to upgrade it?
will the new code and "minimum" rommon combo would still work?
i don't see recommended 16.9(1r) rommon release in the download site for 4331.
https://software.cisco.com/download/home/284358776/type/282046486/release/16.12(2r).
the latest are only 16.12(2r) and 16.7(5r). which one do i choose?
balaji.bandi
if you looking to upgrade 16.9.X  you need to refer release notes of 16.9.X
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/release/xe-16-9/isr4k-rel-notes-xe-16-9.html#con_180601
BB
hi,
the link's a bit lengthy but will parse through it. thanks!
balaji.bandi
yes i know bit work of reading, but end you understand and caveats if any, since you managing the network, we need know any issues around before upgrade as part of  audit
BB
