Cisco 4431 Router licensing
ohareka70
Level 3
Level 3
I have a 1GB connection from my DMZ network to the internet.  It travels from the 1GB cisco switch to the 1GB Cisco 4431 router and then into the internet connection.  I have this on 2 different sites.  One of my sites is ok and i can get download speeds of up to 800mb.  But the other site is only getting around 400mb.
My reseller is now saying i only bought a 1GB license for the cisco 4431 and that i should have bought a 2GB license is a synchronous license instead of asynchronous
This is what is showing under
 show run config
router#
license udi pid ISR4331/K9
license boot level appxk9
any ideas if he is correct as i have never heard of this before
But as i say its working fine at one site and both routers are identical with the same licenses
thanks in advance,Kevin
4 Accepted Solutions
Philip D'Ath
The ISR 4431 has a base thoughput of 500Mb/s.  You'll need to buy a licence to lift that to 1Gb/s.
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
ps.  Use the below command to confirm which performance licence you have installed.
sh platform hardware throughput level
Your right
The current throughput level is 500000 kb/s
looks like i have to think about a new license
thanks for your help
>The 1Gb licenses are asynchronous, not 1Gb each way.
>Does that mean i have 500mb up and 500mb down
It means the total throughput in both directions can not exceed 1Gb/s.  So you could download 800Mb/s and upload 200Mb/s and be ok.  Just the some of the up and downstream can not exceed 1Gb/s at any particular moment in time.
6 Replies 6
Philip D'Ath
Your right
Hello, just one more question
Here is my output
The current throughput level is 1000000 kb/s
But the supplier is saying
What do you think?
Excellent answer - that explains what i am seeing in my speed test results
I know i have a line fault at one site because i cannot get over 400mb but at the other site i can range from 600 to 800
much appreciated
Kevin
