10-11-2013 02:28 AM - edited 03-04-2019 09:17 PM
My name is Ardit Vallja from ITirana Shpk ISP in Albania,
We have a problem with one Cisco C7200 NPE-G1. The IOS on flash (bootflash) is deleted and the router is in rommon mode.
The ftp/tftp transfer is not possible because the router does not allow some commands.
We are trying to add ios on flash card and boot the router from there but the flash card (PCICMA) seems to be corrupted because it is formated form another version of Cisco router.
rommon 8 > dir bootflash:
File size Checksum File name
6719992 bytes (0x6689f8) 0x9568f04d c7200-kboot-mz.123-15b.bin (deleted)
rommon 9 > dir disk2:
open: file "c7200-atafslib-m" not found
open(): Open Error = -1
loadprog: error - on file open
cannot load the monitor library "disk2:%c7200-atafslib-m" from device: PCMCIA compact flashdir: cannot open device "disk2:"
Looking forward to your response for any solution,
10-11-2013 06:21 AM
You can boot IOS directly from TFTP.
Then in IOS load try formatting, replacing flash, etc.
10-11-2013 06:28 AM
I've got this error when try to boot IOS from TFTP:
rommon 16 > boot tftp:c7200p-adventerprisek9-mz.124-24.T6.bin
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
boot: cannot load "tftp:c7200p-adventerprisek9-mz.124-24.T6.bin"
rommon 17 > boot tftp://192.168.10.200/c7200p-adventerprisek9-mz.124-24.T6.bin
boot: cannot load "tftp://192.168.10.200/c7200p-adventerprisek9-mz.124-24.T6.bin"
rommon 18 >
rommon 18 > set
PS1=rommon ! >
WARM_REBOOT=
RET_2_RTS=00:23:03 UTC Sun Feb 13 2005
RET_2_RCALTS=1108254183
RELOAD_TYPE=1
IOMEM_SIZE=
BSI=-1
RANDOM_NUM=171245516
IP_ADDRESS=192.168.10.100
IP_SUBNET_MASK=255.255.255.0
DEFAULT_GATEWAY=192.168.10.200
TFTP_SERVER=192.168.10.200
TFTP_FILE=c7200p-adventerprisek9-mz.124-24.T6.bin
BOOT=
BOOTLDR=
?=1
