Cisco 7204VXR OC3 Output drops increasing
ahmad82pkn
Level 3
Level 3
Hello Team,
Any idea why my OC3 interface is showing increasing output drops its starts happening as soon traffic exceed 60Mbps   ( FYI my traffic never exceeded 75Mbps MAX, and circuit is 150Mbps from carrier , full OC3)
Any thoughts how i can fix this? Below are few stats as starter.
IOS i am using is c7200p-is-mz.122-31.SB10.bin
sh int pos1/1
POS1/1 is up, line protocol is up
  Hardware is Packet over Sonet
  Internet address is x.x.x.x
  MTU 4470 bytes, BW 155000 Kbit, DLY 100 usec,
     reliability 255/255, txload 83/255, rxload 36/255
  Encapsulation PPP, LCP Open
  Stopped: CDPCP
  Open: IPCP, crc 16, loopback not set
  Keepalive set (10 sec)
  Scramble enabled
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 1w1d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 57260637
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 21988000 bits/sec, 27871 packets/sec
  5 minute output rate 51053000 bits/sec, 26240 packets/sec
     1754515820 packets input, 3457578272 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     1 runts, 18 giants, 0 throttles
              0 parity
     422 input errors, 418 CRC, 0 frame, 0 overrun, 0 ignored, 4 abort
     1667079744 packets output, 2951488384 bytes, 0 underruns
     0 output errors, 0 applique, 242 interface resets
     0 carrier transitions
sh controllers pos 1/1
POS1/1
SECTION
  LOF = 0          LOS    = 0                            BIP(B1) = 0
LINE
  AIS = 0          RDI    = 0          FEBE = 0          BIP(B2) = 0
PATH
  AIS = 0          RDI    = 0          FEBE = 0          BIP(B3) = 0
  PLM = 5          UNEQ   = 0          TIM  = 0          TIU     = 0
  LOP = 0          NEWPTR = 0          PSE  = 3          NSE     = 0
Active Defects: None
Active Alarms:  None
Alarm reporting enabled for: SF SLOS SLOF B1-TCA B2-TCA PLOP B3-TCA
Framing: SONET
APS
  COAPS = 0          PSBF = 0
  State: PSBF_state = False
  Rx(K1/K2): 00/00  Tx(K1/K2): 00/00
  S1S0 = 00, C2 = 16
  Remote aps status (none); Reflected local aps status (none)
CLOCK RECOVERY
  RDOOL = 0
  State: RDOOL_state = False
PATH TRACE BUFFER: STABLE
  Remote hostname : dca-priv-03 so-7/1/2
  Remote interface:
  Remote IP addr  :
  Remote Rx(K1/K2):   /    Tx(K1/K2):   /
BER thresholds:  SF = 10e-3  SD = 10e-6
TCA thresholds:  B1 = 10e-6  B2 = 10e-6  B3 = 10e-6
  Clock source:  line
Interface POS1/1
dma mode : push
Hardware is Packet over SONET (hwidb=0x3EB91F0)
fastsend            = 0x0085CE44, turbofs    = 0x05DFBF60
multicast fs        = 0x00000000
SFP is SFP-OC3-MM OC3 MM
Serial Number : YAAY0016
Framer is PMC PM5379 S/UNI-4x155 1 0
Receive side:
  1455581673090 bytes, 10348619754 frames, 1 overrun interrupts
Transmit side:
  3297935862601 bytes, 10260849591 frames, 0 aborts
PHY link is UP
Device instance   = 0x03EBB3D8
PCI device base   = 0xE0000000, Framer base       = 0xE0010000
TX FPGA base      = 0xE00A0000, RX FPGA base      = 0xE04A0000
TX SRAM base      = 0xE0200000, RX SRAM base      = 0xE0600000
TX SRAM size (KB) = 0         , RX SRAM size (KB) = 0
TX PLX base       = 0xE0000000, RX PLX base       = 0xE0400000
PA TX ring base   = 0x00000000, PA RX ring base   = 0xE04B0000
TX ring base      = 0x00000000, RX ring base      = 0x385A5E80
tx_upd_addr       = 0x38377240, tx_write_addr     = 0xE00C0000
txr_mp_shadow     = 0x00000000, txr_pak_shadow    = 0x00000000
rx_upd_addr       = 0x38387340, rx_upd_addr (val) = 91
rxr_shadow        = 0x03EBB784, rx_pak            = 0x03CA4274
max_particles=36, input_err_rate=0, tx_fullring=0
tx_limited=0, mci_txcount_enabled=0, mci_txcount=256
rx_head=75, tx_head=0, tx_tail=0, tx_count=1
rx_int=3435852815, tx_int=578546419
rx_enabled=1
TX FPGA registers:
reset           = 0x2C000100, abrt_cnt           = 0x00000000
wr_ptr          = 0x0005EAE0, rd_ptr             = 0x0005EAE0
part_size       = 0x00000000, bd_wr_cnt          = 0x02050700
act_bd_idx      = 0xAA55AA55, lst_rcvd_bd_idx    = 0xAA55AA55
fifo_full       = 0xAA55AA55, fifo_full_upd_addr = 0x38377240
led_cntrl       = 0x00000000, pak_cnt_back       = 0x6398E6AE
pak_cnt_front   = 0x6398E6AE, no_traf_lat_timer  = 0xAA55AA55
dbg_reg_front   = 0x00000000, dbg_reg_back       = 0x00000000
RX FPGA registers:
reset           = 0x43000008, fifo_full_cnt      = 0xAA55AA55
wr_ptr          = 0x0004BAD8, rd_ptr             = 0x0004BAD4
pkt_index_addr  = 0x38387340, hst_rng_strt       = 0x385A5E80
part_size       = 0xAA55AA55, bd_wr_cnt          = 0xAA55AA55
actv_bd_idx     = 0x80000077, lst_rcvd_bd_idx    = 0x0000006D
lst_part_wr_ptr = 0x0004BD78, int_idle_tmr       = 0xAA55AA55
bad_bd_rx_fifo  = 0x00000000, clock_select       = 0x00000000
sfp_reg         = 0x00000020, pak_cnt_host       = 0x0072C13D
pak_fmr_good    = 0x0072DA6F, pak_fmr_err        = 0x00000000
dbg_reg_int_sm  = 0x003A0042, dbg_reg_pl3_mict   = 0xAA55AA55
TX PLX registers:
cfid     = 0x905610B5, cfcs     = 0x02B00006, cfrv  = 0x068000BA
cflt     = 0x0000FF00, cbmem    = 0xE0000000, cbio  = 0x00000001
cblocal0 = 0xE0000000, cblocal1 = 0x00000000, cbrom = 0x00000000
cfit     = 0x00000100
range_pci_local0    = 0xFFC00000, remap_pci_local0        = 0x00010001
mode_arb_reg        = 0x03200000, big_little_endian_reg   = 0x00300500
range_pci_rom       = 0x00000000, remap_pci_rom           = 0x0000001F
bus_desc_pci_local0 = 0x410301C3, range_local_pci         = 0x00000000
cb_local_pci        = 0x00000000, cb_local_pci_io         = 0x00000000
remap_local_pci     = 0x000004A9, cfg_addr_reg_lcl_pci_io = 0x00000000
dma_chan0_mode      = 0x000001C3, dma_chan1_mode          = 0x000001C3
range_pci_local1    = 0xFFFFFFF0, remap_pci_local1        = 0x00000000
bus_desc_pci_local1 = 0x0000010B
RX PLX registers:
cflt     = 0x0000FF00, cbmem    = 0xE0400000, cbio  = 0x00000001
cblocal0 = 0xE0400000, cblocal1 = 0x00000000, cbrom = 0x00000000
cfit     = 0x00000100
range_pci_local0    = 0xFFC00000, remap_pci_local0        = 0x00420001
bus_desc_pci_local0 = 0x41030143, range_local_pci         = 0x00000000
17 Replies 17
ahmad82pkn wrote:
Above Gi0/1 information is my LAN side of the router, so you mean they is so much traffic entring the router from LAN ?
note: POS1/1 is my WAN side.
so i need two WAN circuits? if so then what is the benefit of having OC3 card/ circuit on 7204 which is half utilized?
Half utilized on average, but also unable to keep up with bursts coming from three gigabit interface.
Performances aren't cheap
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Input queue drops aren't unusual on 7200 gig interfaces; often indicates CPU can't keep up with a burst of packets at gig rate.  BTW, what "engine" are you using?
Like egress queuing, one possible solution is to increase input queue depth.  Assuming traffic is bursty, this gives the chance for the CPU to catch up between bursts.
Another possible solution might be to run gig interfaces (especially if you have multiple active) at 100 Mbps, or if possible, have other LAN side device shape slower sending to your 7200.  Here the idea is to allow the 7200 more time to process each packet.
NB: running gig interfaces at 100 Mbps shouldn't be too detrimental if your average traffic is only 60 to 75 Mbps, but if you can't shape to the 7200 and you want more than 100 Mbps (to take full advantage of your OC3), another possible solution might be to run two LAN interfaces at 100 Mbps in an Etherchannel configuration.
NB: gig (duplex) Ethernet can require up to about 3 MPPS to maintain wirerate, and even the NPE-G2 only provides 2 MPPS (fast path) - this is why its forwarding can fall behind with gig bursts.
ahmad82pkn
Level 3
Level 3
Hi Team, Sorry for coming back late on this.
Thank you for your useful input on this thread.
after changing queue value from 40 to 100, my one issue is resolved that is previously i had 5 to 8% packet loss on circuit, now packet loss is gone its a big step forward for me.
Although outdrops are still there, i somehow didnt read Joseph second last reply, in which he suggested 600 queue size, i just read it.
i will definitely try it and see if output drops also vanishes with this, as per joseph suggestion i have hold my carrier for juniper to cisco movement on their end for the circuit.
will get back tou you guys soon after chaning queue to 600
here are my current stat at peak time
sh int pos1/1
Description WAN SIDE
     reliability 255/255, txload 119/255, rxload 50/255
  Stopped: CDPCP
  Scramble enabled
  Last clearing of "show interface" counters 5d11h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1780162
  Output queue: 0/100 (size/max)
  5 minute input rate 30751000 bits/sec, 36164 packets/sec
  5 minute output rate 72895000 bits/sec, 36605 packets/sec
     1510929192 packets input, 3528806243 bytes, 0 no buffer
              0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1745501896 packets output, 1331683932 bytes, 0 underruns
     0 output errors, 0 applique, 0 interface resets
#######################LAN SIDE######################
sh int gi0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 0004.9bd6.cc1b (bia 0004.9bd6.cc1        b)
  Internet address is 10.80.0.8/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 9/255, rxload 17/255
  Full Duplex, 1000Mbps, RJ45, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 0
  30 second input rate 69428000 bits/sec, 29735 packets/sec
  30 second output rate 35568000 bits/sec, 32126 packets/sec
     3981696301 packets input, 1131224550 bytes, 0 no buffer
     Received 20508 broadcasts (166776 IP multicasts)
     2 input errors, 0 CRC, 0 frame, 0 overrun, 2 ignored
     0 watchdog, 625454 multicast, 0 pause input
     4278761853 packets output, 492860961 bytes, 0 underruns
