Cisco 7204VXR OC3 Output drops increasing
ahmad82pkn
Level 3
Level 3
Hello Team,
Any idea why my OC3 interface is showing increasing output drops its starts happening as soon traffic exceed 60Mbps   ( FYI my traffic never exceeded 75Mbps MAX, and circuit is 150Mbps from carrier , full OC3)
Any thoughts how i can fix this? Below are few stats as starter.
IOS i am using is c7200p-is-mz.122-31.SB10.bin
sh int pos1/1
POS1/1 is up, line protocol is up
  Hardware is Packet over Sonet
  Internet address is x.x.x.x
  MTU 4470 bytes, BW 155000 Kbit, DLY 100 usec,
     reliability 255/255, txload 83/255, rxload 36/255
  Encapsulation PPP, LCP Open
  Stopped: CDPCP
  Open: IPCP, crc 16, loopback not set
  Keepalive set (10 sec)
  Scramble enabled
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 1w1d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 57260637
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 21988000 bits/sec, 27871 packets/sec
  5 minute output rate 51053000 bits/sec, 26240 packets/sec
     1754515820 packets input, 3457578272 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     1 runts, 18 giants, 0 throttles
              0 parity
     422 input errors, 418 CRC, 0 frame, 0 overrun, 0 ignored, 4 abort
     1667079744 packets output, 2951488384 bytes, 0 underruns
     0 output errors, 0 applique, 242 interface resets
     0 carrier transitions
sh controllers pos 1/1
POS1/1
SECTION
  LOF = 0          LOS    = 0                            BIP(B1) = 0
LINE
  AIS = 0          RDI    = 0          FEBE = 0          BIP(B2) = 0
PATH
  AIS = 0          RDI    = 0          FEBE = 0          BIP(B3) = 0
  PLM = 5          UNEQ   = 0          TIM  = 0          TIU     = 0
  LOP = 0          NEWPTR = 0          PSE  = 3          NSE     = 0
Active Defects: None
Active Alarms:  None
Alarm reporting enabled for: SF SLOS SLOF B1-TCA B2-TCA PLOP B3-TCA
Framing: SONET
APS
  COAPS = 0          PSBF = 0
  State: PSBF_state = False
  Rx(K1/K2): 00/00  Tx(K1/K2): 00/00
  S1S0 = 00, C2 = 16
  Remote aps status (none); Reflected local aps status (none)
CLOCK RECOVERY
  RDOOL = 0
  State: RDOOL_state = False
PATH TRACE BUFFER: STABLE
  Remote hostname : dca-priv-03 so-7/1/2
  Remote interface:
  Remote IP addr  :
  Remote Rx(K1/K2):   /    Tx(K1/K2):   /
BER thresholds:  SF = 10e-3  SD = 10e-6
TCA thresholds:  B1 = 10e-6  B2 = 10e-6  B3 = 10e-6
  Clock source:  line
Interface POS1/1
dma mode : push
Hardware is Packet over SONET (hwidb=0x3EB91F0)
fastsend            = 0x0085CE44, turbofs    = 0x05DFBF60
multicast fs        = 0x00000000
SFP is SFP-OC3-MM OC3 MM
Serial Number : YAAY0016
Framer is PMC PM5379 S/UNI-4x155 1 0
Receive side:
  1455581673090 bytes, 10348619754 frames, 1 overrun interrupts
Transmit side:
  3297935862601 bytes, 10260849591 frames, 0 aborts
PHY link is UP
Device instance   = 0x03EBB3D8
PCI device base   = 0xE0000000, Framer base       = 0xE0010000
TX FPGA base      = 0xE00A0000, RX FPGA base      = 0xE04A0000
TX SRAM base      = 0xE0200000, RX SRAM base      = 0xE0600000
TX SRAM size (KB) = 0         , RX SRAM size (KB) = 0
TX PLX base       = 0xE0000000, RX PLX base       = 0xE0400000
PA TX ring base   = 0x00000000, PA RX ring base   = 0xE04B0000
TX ring base      = 0x00000000, RX ring base      = 0x385A5E80
tx_upd_addr       = 0x38377240, tx_write_addr     = 0xE00C0000
txr_mp_shadow     = 0x00000000, txr_pak_shadow    = 0x00000000
rx_upd_addr       = 0x38387340, rx_upd_addr (val) = 91
rxr_shadow        = 0x03EBB784, rx_pak            = 0x03CA4274
max_particles=36, input_err_rate=0, tx_fullring=0
tx_limited=0, mci_txcount_enabled=0, mci_txcount=256
rx_head=75, tx_head=0, tx_tail=0, tx_count=1
rx_int=3435852815, tx_int=578546419
rx_enabled=1
TX FPGA registers:
reset           = 0x2C000100, abrt_cnt           = 0x00000000
wr_ptr          = 0x0005EAE0, rd_ptr             = 0x0005EAE0
part_size       = 0x00000000, bd_wr_cnt          = 0x02050700
act_bd_idx      = 0xAA55AA55, lst_rcvd_bd_idx    = 0xAA55AA55
fifo_full       = 0xAA55AA55, fifo_full_upd_addr = 0x38377240
led_cntrl       = 0x00000000, pak_cnt_back       = 0x6398E6AE
pak_cnt_front   = 0x6398E6AE, no_traf_lat_timer  = 0xAA55AA55
dbg_reg_front   = 0x00000000, dbg_reg_back       = 0x00000000
RX FPGA registers:
reset           = 0x43000008, fifo_full_cnt      = 0xAA55AA55
wr_ptr          = 0x0004BAD8, rd_ptr             = 0x0004BAD4
pkt_index_addr  = 0x38387340, hst_rng_strt       = 0x385A5E80
part_size       = 0xAA55AA55, bd_wr_cnt          = 0xAA55AA55
actv_bd_idx     = 0x80000077, lst_rcvd_bd_idx    = 0x0000006D
lst_part_wr_ptr = 0x0004BD78, int_idle_tmr       = 0xAA55AA55
bad_bd_rx_fifo  = 0x00000000, clock_select       = 0x00000000
sfp_reg         = 0x00000020, pak_cnt_host       = 0x0072C13D
pak_fmr_good    = 0x0072DA6F, pak_fmr_err        = 0x00000000
dbg_reg_int_sm  = 0x003A0042, dbg_reg_pl3_mict   = 0xAA55AA55
TX PLX registers:
cfid     = 0x905610B5, cfcs     = 0x02B00006, cfrv  = 0x068000BA
cflt     = 0x0000FF00, cbmem    = 0xE0000000, cbio  = 0x00000001
cblocal0 = 0xE0000000, cblocal1 = 0x00000000, cbrom = 0x00000000
cfit     = 0x00000100
range_pci_local0    = 0xFFC00000, remap_pci_local0        = 0x00010001
mode_arb_reg        = 0x03200000, big_little_endian_reg   = 0x00300500
range_pci_rom       = 0x00000000, remap_pci_rom           = 0x0000001F
bus_desc_pci_local0 = 0x410301C3, range_local_pci         = 0x00000000
cb_local_pci        = 0x00000000, cb_local_pci_io         = 0x00000000
remap_local_pci     = 0x000004A9, cfg_addr_reg_lcl_pci_io = 0x00000000
dma_chan0_mode      = 0x000001C3, dma_chan1_mode          = 0x000001C3
range_pci_local1    = 0xFFFFFFF0, remap_pci_local1        = 0x00000000
bus_desc_pci_local1 = 0x0000010B
RX PLX registers:
cflt     = 0x0000FF00, cbmem    = 0xE0400000, cbio  = 0x00000001
cblocal0 = 0xE0400000, cblocal1 = 0x00000000, cbrom = 0x00000000
cfit     = 0x00000100
range_pci_local0    = 0xFFC00000, remap_pci_local0        = 0x00420001
bus_desc_pci_local0 = 0x41030143, range_local_pci         = 0x00000000
17 Replies 17
paolo bevilacqua
Which NPE?
Config ?
Show proc cpu ?
Show int switching ?
1-NPE-G2
2- sh run int pos1/1
ip address x.x.x
ip accounting output-packets
ip flow ingress
encapsulation ppp
pos scramble-atm
About show proc cpu and show in switching, i will post output tomorrow when issue is occuring, at this time, traffic is less than 30Mbps and issue not occuring. will post tomorrow. thank you for your participation
ahmad82pkn
Level 3
Level 3
here is output of show process cpu
HAMP7204VXR#sh processes cpu
CPU utilization for five seconds: 49%/49%; one minute: 50%; five minutes: 51%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0         3          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2        1052   5385769          0  0.00%  0.00%  0.00%   0 Load Meter
   3           0      5135          0  0.00%  0.00%  0.00%   0 TACACS+
   4     6493648   2735131       2374  0.00%  0.04%  0.00%   0 Check heaps
   5         776     12209         63  0.00%  0.00%  0.00%   0 Pool Manager
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
   7           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
   8           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
   9           0         2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  10           0         2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  11         196   5385408          0  0.00%  0.00%  0.00%   0 ALARM_TRIGGER_SC
  12           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  13         308    406737          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  14           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  15           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  16   116983612 484040505        241  0.00%  0.26%  0.17%   0 EnvMon
  17           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  18          16    448855          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  19           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  20        1076  26917929          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  21           0         1          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  22         680  26917929          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  23           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  24           0         1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  25          68   2693014          0  0.00%  0.00%  0.00%   0 Compute SRP rate
  26      207872   4714253         44  0.00%  0.00%  0.00%   0 ARP Input
  27        2096  28077569          0  0.00%  0.00%  0.00%   0 ARP Background
  28           8       577         13  0.00%  0.00%  0.00%   0 EEM ED Syslog
  29           0         1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  30           0        10          0  0.00%  0.00%  0.00%   0 DDR Timers
  31           0         6          0  0.00%  0.00%  0.00%   0 Entity MIB API
  32           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  33           0         1          0  0.00%  0.00%  0.00%   0 RFS server proce
  34         772  26917927          0  0.00%  0.00%  0.00%   0 GraphIt
  35           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  36           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  37     4840536   8725271        554  0.07%  0.02%  0.02%   0 Net Background
  38           0         2          0  0.00%  0.00%  0.00%   0 IDB Work
  39           4       917          4  0.00%  0.00%  0.00%   0 Logger
  40        1712  26917923          0  0.00%  0.00%  0.00%   0 TTY Background
  41       47752  26918101          1  0.07%  0.05%  0.07%   0 Per-Second Jobs
  42     2068352    458658       4509  0.00%  0.00%  0.00%   0 Per-minute Jobs
  43           0         2          0  0.00%  0.00%  0.00%   0 PrstVbl
  44           0         8          0  0.00%  0.00%  0.00%   0 IF-MGR control p
  45           0        97          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  46           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  47        5360   7856895          0  0.00%  0.00%  0.00%   0 HC Counter Timer
  48           0         1          0  0.00%  0.00%  0.00%   0 CSP Timer
  49           0         2          0  0.00%  0.00%  0.00%   0 CES Timer
  50           0         2          0  0.00%  0.00%  0.00%   0 Hawkeye Backgrou
  51           0         1          0  0.00%  0.00%  0.00%   0 FPD Management P
  52           0         1          0  0.00%  0.00%  0.00%   0 FPD Action Proce
  53           0         1          0  0.00%  0.00%  0.00%   0 SONET alarm time
  54           0         1          0  0.00%  0.00%  0.00%   0 POS APS Event Pr
  55           0        35          0  0.00%  0.00%  0.00%   0 Collection proce
  56           4         2       2000  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  57           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  58           0         2          0  0.00%  0.00%  0.00%   0 Flash MIB Update
  59           0         1          0  0.00%  0.00%  0.00%   0 Flash Card Oir
  60           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
  61           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
  62           0       153          0  0.00%  0.00%  0.00%   0 TurboACL
  63           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
  64           0         3          0  0.00%  0.00%  0.00%   0 CEF switching ba
  65           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  66         164      4761         34  0.00%  0.00%  0.00%   0 AAA Server
  67         304      9798         31  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  68        3480 838286867          0  0.00%  0.01%  0.00%   0 ACCT Periodic Pr
  69           0         1          0  0.00%  0.00%  0.00%   0 AAA System Acct
  70          16        58        275  0.00%  0.00%  0.00%   0 IP ARP Adjacency
  71     5616820  82859569         67  0.07%  0.03%  0.02%   0 IP Input
  72           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  73           0         2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
  74        4364 838286890          0  0.00%  0.00%  0.00%   0 IPAM Manager
  75           0         2          0  0.00%  0.00%  0.00%   0 IPAM Events
  76        9460 376854483          0  0.07%  0.03%  0.02%   0 PPP manager
  77          36     43853          0  0.00%  0.00%  0.00%   0 PPP SIP
  78           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
  79           0        15          0  0.00%  0.00%  0.00%   0 PPP IP Route
  80          52     21951          2  0.00%  0.00%  0.00%   0 SSS Manager
  81           0         1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
  82           0        31          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  83        2608 105167290          0  0.00%  0.00%  0.00%   0 SSS Feature Time
  84           0         1          0  0.00%  0.00%  0.00%   0 SG DPM
  85           0         1          0  0.00%  0.00%  0.00%   0 Timer handler fo
  86           0         1          0  0.00%  0.00%  0.00%   0 Prepaid response
  87           0         1          0  0.00%  0.00%  0.00%   0 Timed Policy act
  88           0         1          0  0.00%  0.00%  0.00%   0 AAA response han
  89          20     65831          0  0.00%  0.00%  0.00%   0 SSM connection m
  90           0         2          0  0.00%  0.00%  0.00%   0 Spanning Tree
  91         368  11599288          0  0.00%  0.00%  0.00%   0 BGP Scheduler
  92           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  93           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
  94           0         2          0  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
  95           0         1          0  0.00%  0.00%  0.00%   0 TC SIP
  96           0         2          0  0.00%  0.00%  0.00%   0 IP PORTBUNDLE
  97           0         1          0  0.00%  0.00%  0.00%   0 SG CMD HANDLER
  98         136   6575070          0  0.00%  0.00%  0.00%   0 IP SIP Process
  99        3888 838286922          0  0.00%  0.00%  0.00%   0 RADIUS Proxy
100           0         1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Redistr
101        7140    538646         13  0.00%  0.00%  0.00%   0 CEF background p
102           0         1          0  0.00%  0.00%  0.00%   0 IP IRDP
103           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
104           0         3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
105       12364  37757172          0  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
106           0       135          0  0.00%  0.00%  0.00%   0 ADJ background
107       131322405976846          0  0.07%  0.11%  0.10%   0 HQF Shaper Backg
108           0         1          0  0.00%  0.00%  0.00%   0 HQF IDB Associat
109        4056  28933121          0  0.00%  0.00%  0.00%   0 TCP Timer
110         312      3015        103  0.00%  0.00%  0.00%   0 TCP Protocols
111        1284  27912991          0  0.00%  0.00%  0.00%   0 Socket Timers
112           0     89774          0  0.00%  0.00%  0.00%   0 HTTP CORE
113           0         2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
114           0         1          0  0.00%  0.00%  0.00%   0 Probe Input
115           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
116        6976  53820079          0  0.00%  0.00%  0.00%   0 DHCPD Receive
117        4344    593046          7  0.00%  0.00%  0.00%   0 IP Background
118        2392    454208          5  0.00%  0.00%  0.00%   0 IP RIB Update
119       77400   4027628         19  0.00%  0.00%  0.00%   0 CDP Protocol
121           0         2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
122           0         2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
123        3436 268535314          0  0.00%  0.00%  0.00%   0 RBSCP Background
124           0         1          0  0.00%  0.00%  0.00%   0 COPS
125           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
126           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
127           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
128           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
129         428   5385719          0  0.00%  0.00%  0.00%   0 L2F management d
130           0         1          0  0.00%  0.00%  0.00%   0 PPTP Mgmt
131           0         2          0  0.00%  0.00%  0.00%   0 IP Inband Sessio
132           0         3          0  0.00%  0.00%  0.00%   0 gk process
133           0         3          0  0.00%  0.00%  0.00%   0 LOCAL AAA
134           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
135           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
136           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
137          20     21938          0  0.00%  0.00%  0.00%   0 IDMGR CORE
138        8072     78128        103  0.00%  0.00%  0.00%   0 TPLUS
139           0         1          0  0.00%  0.00%  0.00%   0 TSP
140           0         1          0  0.00%  0.00%  0.00%   0 VOIP RTP Udp Inp
141           0         1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
142           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_HTSP
143           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
144           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
145           0         2          0  0.00%  0.00%  0.00%   0 Proxy Session Ap
146         204   2692995          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
147           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
148           0         1          0  0.00%  0.00%  0.00%   0 SYSMGT Events
149         172     13972         12  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
150           0         1          0  0.00%  0.00%  0.00%   0 SONET Traps
151        1116   5395021          0  0.00%  0.00%  0.00%   0 EEM Server
152           0         2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
153          76    448887          0  0.00%  0.00%  0.00%   0 EEM ED Timer
154           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Counter
155           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Interface
156           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
157       97708   5440520         17  0.00%  0.00%  0.00%   0 OSPF-6 Hello
158           0         2          0  0.00%  0.00%  0.00%   0 EEM ED None
159           0         3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
160           0         2          0  0.00%  0.00%  0.00%   0 EEM ED OIR
161           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Track
162        3184   1021981          3  0.00%  0.00%  0.00%   0 IP SLA Monitor R
163           0         1          0  0.00%  0.00%  0.00%   0 RMON Packets
164           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
165           0         1          0  0.00%  0.00%  0.00%   0 VPDN Test
166         596  26909884          0  0.00%  0.00%  0.00%   0 trunk conditioni
167           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
168       17140    896720         19  0.00%  0.00%  0.00%   0 Net Input
169        4672   5385740          0  0.00%  0.00%  0.00%   0 Compute load avg
170           0         1          0  0.00%  0.00%  0.00%   0 TCP Driver
171           0         3          0  0.00%  0.00%  0.00%   0 TCP Listener
172          16    224430          0  0.00%  0.00%  0.00%   0 CC-API_VCM
173        5936 268535381          0  0.00%  0.00%  0.00%   0 CCPROXY_CT
174           0         1          0  0.00%  0.00%  0.00%   0 CCPROXY_UDP
175      449224  10554985         42  0.00%  0.00%  0.00%   0 IP SNMP
176      115220   5413339         21  0.00%  0.00%  0.00%   0 PDU DISPATCHER
177      919316   9276850         99  0.00%  0.00%  0.00%   0 SNMP ENGINE
178        4884       134      36447  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
179           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
180        1880  27332074          0  0.00%  0.00%  0.00%   0 NTP
181           0         1          0  0.00%  0.00%  0.00%   0 xcpa-driver
182          24    224429          0  0.00%  0.00%  0.00%   0 DHCPD Timer
183          16    448860          0  0.00%  0.00%  0.00%   0 DHCPD Database
184           8        29        275  0.00%  0.00%  0.00%   0 IP-EIGRP Router
185      154404  18526276          8  0.00%  0.00%  0.00%   0 IP-EIGRP(0): PDM
186          44       102        431  0.07%  0.02%  0.00%   2 Virtual Exec
187        7220  26477679          0  0.00%  0.00%  0.00%   0 OSPF-6 Router
188      111060  42769069          2  0.00%  0.00%  0.00%   0 IP-EIGRP(0): HEL
189       11032 376865574          0  0.00%  0.01%  0.00%   0 PPP Events
190         520  12099464          0  0.00%  0.00%  0.00%   0 Multilink PPP
191           0         1          0  0.00%  0.00%  0.00%   0 Multilink event
192       14212   1210683         11  0.00%  0.00%  0.00%   0 BGP Router
193       12184   1179968         10  0.00%  0.00%  0.00%   0 BGP I/O
194       95920    792096        121  0.00%  0.00%  0.00%   0 BGP Scanner
195           0         2          0  0.00%  0.00%  0.00%   0 BGP Event
196           0         1          0  0.00%  0.00%  0.00%   0 IP Flow Backgrou
the show interface switching command doesnt seem to be recognized in my IOS.
HAMP7204VXR#sh interfaces pos1/1 swi?
% Unrecognized command
HAMP7204VXR#sh int swi
HAMP7204VXR#sh int swi?
Just type show interface x/y switching and include the command.
Also include show interface and show running interface, for the interface where packets are input first.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
How do you know your traffic never exceeds 75 Mbps, especially down at millisecond intervals?
Assuming you have transient burst congestion, try setting your queue depth to support about 1/2 BDP (bandwidth delay product).  (I suspect the default 40 is too shallow.)
That is right, 40 can be too little for OC3.
Note that when doign calculation on Internet routers, one cannot know the delay, because they talk to all the world.
Disclaimer
Posting
Agreed, but you could either calculate based on where most traffic goes or calculate for worst case, perhaps 250 ms for the latter.
ahmad82pkn
Level 3
Level 3
So should i change my queue setting to 80?
if yes will below command be correct?
int pos1/1
  hold-queue 80
or i need to change my queueing strategey from FIFO to RED?
which one to try frist? Since its production router, and making a single change need lots of approvals process:-s
What is you input interface, gigabit? If so you can increase hold-queue to 100 or 200 wothjout any problem.
Yes there are 3 Giga and 1 Fast interface, and any one could be Input side ,  OC3 is on MPLS side and connecting to carrier.
i will try 100 and lets hope it makes improvement. will keep you updated.
(Just FYI, Carrier end router is Juniper, and they just updated me they are planning to move my circuit over to Cisco on their end as well, Not sure if it will make any difference, but i will definitely update output of both activities and keep you guys posted)
Disclaimer
Posting
I advise against using (W)RED unless you understand how to tune it, especially as Cisco defaults aren't often optimal.
Would suggest increasing queue depth first.  As Paolo suggests, 100 or 200 shouldn't be a problem; or even larger.
For example, assuming 150 Mbps with 100 ms latency and 1500 sized packets, BDP would be 1,250 packets for the queue.  I suggested 1/2 BDP, so up to about 600 might be considered.
PS:
Unlikely you'll see a difference if other side is Cisco vs. Juniper equipment.
ahmad82pkn
Level 3
Level 3
Also here are stats of my most congested input interface,
It has 75Mbps traffic at this time, but it dont has packet drop or queue drops, though it has default 0/40 queue strategy.
sh int gi0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 0004.9bd6.cc1b (bia 0004.9bd6.cc1        b)
  Internet address is 10.80.0.8/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 8/255, rxload 18/255
  Full Duplex, 1000Mbps, RJ45, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 10w0d
  Input queue: 0/75/31543/0 (size/max/drops/flushes); Total output drops: 0
  30 second input rate 72935000 bits/sec, 31146 packets/sec
  30 second output rate 32239000 bits/sec, 33355 packets/sec
     593384955 packets input, 1626177081 bytes, 0 no buffer
     Received 10742121 broadcasts (1313592 IP multicasts)
     0 watchdog, 4917320 multicast, 0 pause input
     304217807 packets output, 1314771371 bytes, 0 underruns
You have a little bit too much input for your WAN circuit
If you don't want to penalize traffic, it might be time to upgrade circuit or add another one.
Above Gi0/1 information is my LAN side of the router, so you mean they is so much traffic entring the router from LAN ?
note: POS1/1 is my WAN side.
so i need two WAN circuits? if so then what is the benefit of having OC3 card/ circuit on 7204 which is half utilized?
