Cisco 7206 ios Version 15.2(4)M7 support IKEV2
CCIE Aspirant
Hi all,
i am doing a lab in GNS3 using 7200 ios Version 15.2(4)M7 and also have Version 12.4(24)T8, i wants to use IKev2
but i am unable to issue the command
crypto ikev2 proposal default
encryption des
integrity md5
group 1
i am able to use this command on cisco 2911 router. i have tried this command on real device as well but still i get the following error.
R1(config)#crypto ikev2 proposal default
% Invalid input detected at '^' marker.
so question from all of the guys here does it supports IKEv2 or not ?
or what alternative i can use for it?
6 Replies 6
balaji.bandi
i am afraid 7200 images GSN3 support that feature you looking, but i suggest (tested) either use the latest IOL  image is 15.4.X  or use CSR1000v
BB
Hi Balaji,
thanks for your reply
i have version 15 and i have tested it both at Gns3 as well as at device itself. so is there any suggestion how we can use ikev2 on it as i dont want to use ikev1.
you need vios-adventerprisek9-m.vmdk.SPA.156-2.T, which is a Cisco VIRL version. It is not free, you have to get a subscription to VIRL. There currently is no free image available for GNS3 that supports IKEv2 for the 7200 appliance.
hi George,
so what we have to do for real device?
what is the alternative for VXR 7206 to use IKev2?
Try the version attached.
dear georg,
i have tested this image and i get this error.
this may be gns3 setting issue or something else and i will try to check it.
R28 = 0x00000000 R29 = 0x00000000 R30 = 0x00000000 R31 = 0x90440010
No warm reboot Storage
14:41:24 UTC Mon Sep 14 2020: Unexpected exception to CPU: vector 300, PC = 0x24A3850 , LR = 0x24A7D50
-Traceback= 0x24A3850z 0x24A7D50z 0x24A7D28z 0x2B28B64z 0x2B53690z 0x2B260B4z 0x2B50AE0z 0x2CDB5A8z 0x2CD7B58z 0x2CD8688z 0x2CDF810z 0x2AEDC08z 0x2AED4B8z 0x9288FCz 0x928B40z 0x30049ECz
CPU Register Context:
PC = 0x024A3850 MSR = 0x00009032 CR = 0x24002044 LR = 0x024A7D50
CTR = 0x024659EC XER = 0x20000000 DAR = 0x90440070 DSISR = 0x40000000
DEC = 0x00000A2C TBU = 0x00000000 TBL = 0x4F49711E MSSCR0= 0x00000000
R0 = 0x024A7D28 R1 = 0x05BAAE40 R2 = 0x00000000 R3 = 0x90440010
R4 = 0x00000000 R5 = 0x0000002C R6 = 0xF1000014 R7 = 0x0572AE3C
R8 = 0x053D0000 R9 = 0x90440070 R10 = 0x0000000B R11 = 0x00000001
R12 = 0x24002044 R13 = 0x00000000 R14 = 0x05BAB173 R15 = 0x05BAB09B
R16 = 0x05BAB141 R17 = 0x00000000 R18 = 0x05BAB120 R19 = 0x05297824
R20 = 0x05BAAF90 R21 = 0x05297818 R22 = 0x00000002 R23 = 0x00000000
R24 = 0x05BAB100 R25 = 0x05BAAE7C R26 = 0x05BAAE50 R27 = 0x00000001
