Bookmark
Subscribe
381
Cisco 7500 RSP
mounir.mohamed
Level 7
Level 7
WHat is the commands to login to the RSP from the router enable mode to check the uptime of the rsp
marikakis
Level 7
Level 7
If you are logged in, then you are on the active RSP.
So, you can do a "show version" from there.
The uptime shown is the one of the RSP.
From what I remember, the uptime shown there is not affected by
VIP crashes or RSP-RESTART (Cbus complex and the like).
Only a reload or power-on have I seen to make a difference.
You can also try a "show diag", to see if there is more information there
about recent crashes.
If you want to connect to any of the VIP cards,
there is the hidden (and therefore not supported) "if-con ".
You use "if-quit" to quit the session.
I think this doesn't work for an RSP slot.
marikakis
Level 7
Level 7
