Cisco 800 behind Providers Router
silvakizir
Hi.
I have a Providers Router and a Cisco 886 Router.
I want for some reason to have the RJ11 DSL Cable connected with the Providers Router and then I want to connect an RJ45 cable from the Providers Router to my Cisco 886 Router.
I've set the Providers Router to be pass through and I want the Cisco 886 to negotiate the public IP with the provider and have the VDSL connection on it through the FastEthernet3 port and the RJ45 Cable.
I have the below configuration done.
Can anyone confirm if this will work. If not what should I change?
controller VDSL 0
interface FastEthernet0
description *** LAN ***
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
description *** PPPOE interface ***
no ip address
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip address 10.0.0.0 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer1
description *** VDSL Connection ***
mtu 1492
ip address negotiated
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname xxx@xxx
ppp chap password 0 yyyy
ppp pap sent-username xxx@xxx password 0 yyyy
crypto map CMAP
ip nat inside source list xxxxxx interface Dialer1 overload
5 Replies 5
if the ISP modem is in bridge mode, this should work. Is this the full configiuration (I see a crypto map on the dialer, you might want to remove that) ? Make sure the lines marked in bold are in your config:
controller VDSL 0
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Dialer1
mtu 1492
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
--> no crypto map CMAP
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 10.0.0.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 Dialer 1
Thanks for your time.
Yes I also have the lines in bold.
I've also configured a site to site vpn, that is why you see a CMAP under Dialer1.
I just wanted to concentrate to the DSL part and I put only the specific commands.
so does your dialer get a public IP address ?
I will install it and I will inform you.
Hello
Could possibly append a default route to the dialer interlace aprt from that looks okay.
ip route 0.0.0.0 0.0.0.0 Dialer1
Kind Regards
Paul
