Cisco 800 series router configuration for beginners
eugeneg99
I have just bought my first non-domestic router, a CISCO 887VA-K9 which needs basic configuration to get it working.  I have a copy of the configuration guide (334 pages) and CP Express user's guide (94 pages) and have spent an hour reading but either they are missing something or my brain is too small to figure out step 1.  Would some kind soul please just give me a clue how to get started.  Perhaps from where to download a CP Express installation kit for Windows.
Is the only way via a terminal emulator connected via a serial port ?  Is there a graphical interface I can use ?  Are there any basic tutorials for beginners ?  This is probably the only non-domestic routrer I shall work on so I don't want to invest in a full training course.  I just need enough to plug in the ISP credentials and set up DHCP.
29 Replies 29
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
username dubem password YOUR_PASSWORD
! enable http server -> you should be able to configure via web now
ip http server
You did not configure NAT, that is reason why your local LAN is unable to access internet. Do you have access to internet from router?
# ping 8.8.8.8
Can you post current configuration?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
post your running-config.
Alain
Please understand that you are helping a newbie....always indicate a step by step approach....thanks.
here under is the current config. How do I enable the http and configure the NAT?
MSHIELD#show running-config
Building configuration...
Current configuration : 6586 bytes
! Last configuration change at 12:50:17 UTC Mon May 6 2013 by admin
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname MSHIELD
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging buffered 4096
logging console critical
enable secret 5 $1$PjmY$GRm4BWTG6PZFKj.NC.kgw/
enable password 7 10460C1809031A1903113E2E3679
aaa new-model
aaa authentication login local_auth local
aaa session-id common
memory-size iomem 10
no ip source-route
no ip gratuitous-arps
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 192.168.0.1 192.168.0.99
ip dhcp pool MSHIELD-Pool
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 192.168.0.2 192.168.0.1 8.8.8.8
domain-name multishieldltd.com
no ip bootp server
ip domain name multishieldltd.com
ip inspect audit-trail
ip inspect udp idle-time 1800
ip inspect dns-timeout 7
ip inspect tcp idle-time 14400
ip inspect name autosec_inspect ftp timeout 3600
ip inspect name autosec_inspect http timeout 3600
ip inspect name autosec_inspect rcmd timeout 3600
ip inspect name autosec_inspect realaudio timeout 3600
ip inspect name autosec_inspect smtp timeout 3600
ip inspect name autosec_inspect tftp timeout 30
ip inspect name autosec_inspect udp timeout 15
ip inspect name autosec_inspect tcp timeout 3600
ip cef
login block-for 6 attempts 3 within 5
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ1639C0TZ
username admin password 7 04530E070335445C060C111200
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface FastEthernet4
ip address 41.203.YY.XX 255.255.255.252
ip access-group autosec_firewall_acl in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect autosec_inspect out
ip verify unicast source reachable-via rx allow-default 103
duplex half
speed auto
interface Vlan1
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
router rip
redistribute connected
network 41.0.0.0
network 192.168.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip access-list extended autosec_firewall_acl
permit udp any any eq bootpc
deny   ip any any
logging trap debugging
logging facility local2
access-list 100 permit udp any any eq bootpc
access-list 101 permit udp any any eq bootpc
access-list 102 permit udp any any eq bootpc
access-list 103 permit udp any any eq bootpc
dialer-list 1 protocol ip permit
no cdp run
snmp-server group mygroup v3 auth read root
snmp-server view root iso included
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps license
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop conf
ig
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service
-up
snmp-server enable traps flash insertion removal
snmp-server enable traps adslline
snmp-server enable traps vdsl2line
snmp-server enable traps envmon
snmp-server enable traps c3g
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps mac-notification
snmp-server enable traps energywise
snmp-server enable traps vstack
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-c
hange inconsistency
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps bfd
snmp-server enable traps memory bufferpeak
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps cpu threshold
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps vtp
snmp-server enable traps pw vc
snmp-server enable traps firewall serverstatus
snmp-server enable traps nhrp nhs
snmp-server enable traps nhrp nhc
snmp-server enable traps nhrp nhp
snmp-server enable traps nhrp quota-exceeded
snmp-server enable traps waas
snmp-server enable traps gdoi gm-start-registration
snmp-server enable traps gdoi gm-registration-complete
snmp-server enable traps gdoi gm-re-register
snmp-server enable traps gdoi gm-rekey-rcvd
snmp-server enable traps gdoi gm-rekey-fail
snmp-server enable traps gdoi ks-rekey-pushed
snmp-server enable traps gdoi gm-incomplete-cfg
snmp-server enable traps gdoi ks-no-rsa-keys
snmp-server enable traps gdoi ks-new-registration
snmp-server enable traps gdoi ks-reg-complete
snmp-server enable traps ike policy add
snmp-server enable traps ike policy delete
snmp-server enable traps ike tunnel start
snmp-server enable traps ike tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps ethernet cfm alarm
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vnet-trunk-down
snmp-server host 192.168.0.1 version 3 auth admin
snmp-server host 192.168.0.1 private
snmp-server host 192.168.0.1 public
banner motd ^Cuthorized ^C
line con 0
exec-timeout 5 0
login authentication local_auth
transport output telnet
line aux 0
exec-timeout 15 0
line vty 0 4
password 7 0503030E2D58461B1610031719
transport input telnet
end
Hello Dubem,
- configure NAT
interface Fa4
ip nat outside
interface Vlan1
ip nat inside
ip access-list exten NAT_ACL
deny ip 192.168.0.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 192.168.0.0 0.0.0.255 any
deny ip any any
route-map MAP_ACL
ip nat inside source route-map MAP_ACL interface Fa4 overload
- enable http and https access
ip http server
I noticed that you have no routing configured, just RIP. I do not think that you run RIP with your ISP, probably you were just testing some configuration.
Remove RIP and configure static default route toward internet.
no router rip
ip route 0.0.0.0 0.0.0.0 Fa4 41.203.YY.XX
- IP address 41.203.YY.XX should be IP which ISP assigned to interface toward your router, your next-hop.
Best Regards
Hey grana and Cadet....I love you!
I have been on this for months...lol.
I did what you directed and used my Ip route 0.0.0.0.0 0.0.0.0 Fa4 41. 203. (Isp default gateway address) istread of our WAN IP...then it worked!!!...It worked.!!!!!!..
For the browser-based, i was able to login but the webpage displays nothing.
Grana, You rock!
I will come back tomorrow for the WLAN and Port fowarding. But for today, thanks Grana and Cadet.
If you are really struggling with the command line you could try SDM (
http://software.cisco.com/download/release.html?mdfid=281795035&softwareid=283768243&release=2.5&relind=AVAILABLE&rellifecycle=&reltype=latest ). SDM is a GUI based tool for managing routers - It is a bit more user friendly than the HTTP interface. It is a retired product these days though - it is fine for basic stuff though.
Thaks guys, I went on vacation and resumed a couple of days ago.
What steps should I take to configure the wireless features on my Cisco 881 router. Please help. I appreciate your support so far.
If you have been handed a Cisco router with a router port, a lan switch and an access point all in one, I have to agree with mfurnival and suggest to use Cisco SDM software if this is your first experiance with Cisco.  If you still want to use the CLI, then you can use the example below.
* I don't see any radio interfaces in the configurations above.  Are you sure the model you ordered came with integrated antennas?
! Create an SSID and broadcast:
dot11 ssid MY_SSID
vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii MY_PASSWORD
! Configure the physical interface, assuming you have a Dot11Radio0 interface
interface Dot11Radio0
no shutdown
no ip address
encryption vlan 1 mode ciphers tkip
ssid MY_SSID
! Configure a subinterface
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
! Configure a BVI, where x.x.x.x x.x.x.x is your LAN gateway IP address and subnet mask
interface BVI1
ip address x.x.x.x x.x.x.x
ip nat inside
ip virtual-reassembly
! Modify your VLAN configuration
interface Vlan1
no ip address
ip nat inside
bridge-group 1
! Other commands
bridge 1 route ip
Thanks Danel and Mfurnival. I tried using the SDM and see what I got:
THIS IS AN UNSUPPORTED ROUTER. SDM WILL BE CLOSED AS A RESULT.
I visited cisco's website and found out that my router is not listed to use SDM. My router is 800 series.
I also need to configure Port forwarding on this router and it will be nice if i can use a web-based tool to manage my router.
The router could not also be managed using the IP address when it is typed on the browser's address. It only prompts for username and password once I enter them, a blank page displays on the browser.
If you know of any other web-based or GUI tool please help me with information.
You can use CCP (latest is version 2.7) given your IOS is supported:
http://www.cisco.com/go/ciscocp
Cisco 880 Series 12.4(20)T
i was able to config LAN dhcp successfuly and my default route wored fine, but i my LAN PCs cant ping public DNS IP nor could they browse internet. only my 800 series router could. pls help.
Please post your config
Hi Emma,
Check the Network properties of each computer on your LAN, and ensure that Obtain an IP address automatically is selected. Also ensure that Obtain DNS server address automatically is selected.
Post your config, I think I know, what's the problem
Michael
Thanks you all to your timely response. i got the problem solved. the problem was not from my LAN, every devices in the LAN got appropritate IP from DHCP and can ping my WAN interface IP, only that NAT was not function properly even though i was correctly configured; but this device has a unique statment which needed to be add to my nat inforamtion before nat would ever work well and that is "reversal" i arrive at that by using ? at the end of every command i entered to the router for me to see more useful commands availlable. as a matter of fact the moment i add that, the problem solved every one can connect to the internet. the command "reversal" at the end of NAT overload statement permint NAT in - NAT out on my WAN interface.
