Cisco 800 Series Router
dchristm09
Can you use one of the 4 switch ports that have 100 Mbps for your WAN connection?  I am pretty sure you can just want to be sure as I believe the 800 series specifically the 831 has only 10 Mpbs WAN port.
Dave
2 Accepted Solutions
paolo bevilacqua
For ethernet WAN, useas minimum Cisco 851 or 871 or newer. Other models are really really old.
Based on the spec sheet, the 851 has a 10/100 WAN interface:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6195/product_data_sheet0900aecd8028a9a9.html
However, having a FastEthernet interface doesn't necessarily mean the router can handle that much traffic.  The following sheet is old (2009) but gives an idea of relative performance under specified test conditions.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
On the 881 you cannot change the switchports to routed ports (and I assume the same is true for the 850).  You can set up VLAN SVIs for routing, and that may or may not work for you depending on what functions and services you plan to use.  Not quite the designed concept, but it may work.
paolo bevilacqua
Ok doesn't the 851 still only have an 10 Mbps WAN port?  I just want to make sure I don't lock myselft down to 10 Mbps for internet.  Can you use the LAN ports on this to route traffic out to the WAN?  I would be connecting this to an ASA 5505 on the WAN side.  This is just for home use too, why I am going a bit cheaper.
Ok I am going to give that one a try.  Thanks guys.
