Cisco 827-4v VLAN communication
dmanigo
I am currently replacing a C827 with a C827-4v roouter. The new router is the ADSL router in which a C1751-4v gateway will host CME 3.3..My issue is I have created the necessary VLAN's required on the switch but cannot locate the correct command on the router to pass traffic.
Is the 827-4v router capable of VLAN communication?
spremkumar
Level 9
Level 9
I dont think it supports intervlan routing,i did check the datasheet of 827-4v router and couldnt find anything inline with intervlan routing support in that..
http://cisco.com/en/US/products/hw/routers/ps380/products_data_sheet09186a0080092162.html
regds
