Cisco 837 Routers - Can they do ADSL2 & SDSL?
ViacomOutdoor
We have many LAN-to-LAN's using business ADSL lines. Our ISP will be offereing SDSL and ADSL2, are these 837 routers compatibel? If so will any our router configs need to be changed?
spremkumar
Level 9
Level 9
hi
I feel SHDSL requires routers to support/meet ITU G.991.2 standard but i dont think 837 supports that.
Currently 837 supports only the ADSL specifications..
Pls find the specifications for both SHDSL and ADSL.
G.SHDSL Specifications
• Downstream and upstream symmetrical data rates 192 K to 2.3 Mbps in increments of 64 Kbps
• Globespan G.SHDSL Chipset
• ITU G.991.2 Annex A and Annex B
Cisco 837 Router ADSL Specifications
• ST-Micro DynaMiTe (formerly Alcatel Micro Electronics) ADSL Chipset (20150)
• T1.413 ANSI ADSL DMT issue 2
• G.992.1 ITU G.DMT support
• G.992.2 ITU G.Lite support
• G.992.3 ITU G.hs ADSL type negotiation
you can always refer the datasheets for more info on the same ..
http://cisco.com/en/US/products/hw/routers/ps380/products_data_sheet09186a008010e5c5.html
http://cisco.com/en/US/products/hw/routers/ps380/products_data_sheet09186a0080088733.html
AFAIK Cisco 828 does have the support for GSHDSL but it has reached EOL/EOS status already..
regds
If we need a router for our small UK remote offices to support ADSL2 and SDSL what is the preffered router?
hi
You can check out for possible models in Cisco1700 series which supports both ADSL as well as G.SDSL WIC Cards..
Do find the link which contains the datasheets about the same from where you can choose the model which can fit into ur requirement..
http://cisco.com/en/US/products/hw/routers/ps221/products_data_sheets_list.html
regds
