Cisco 857 ATM issue.
gustavo.dearmas
Hi, i'm trying to configure the ADSL interface of a router 857 with fixed ip but all input packets are received erroneous.
I have tested the line with a router 1721 with the same configuration and it's ok. I have tested the router 857 in other ADSL and it's ok too.
To give enough information I have included a file with the configuration of the router, other one with the exit of a debug and other one with the exit of several commands related to the state of the ATM interface.
Someone knows if some problem exists with the IOS version of this router?
nethelper
Level 3
Level 3
try the following additional settings on your interface:
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
-->dsl operating-mode ansi-dmt
interface ATM0.1 point-to-point
ip address
ip nat outside
-->ip mtu 1452
or
-->ip tcp adjust-mss 1452
ip virtual-reassembly
pvc 8/32
encapsulation aal5snap
Check if that makes a difference, if not, post back...
Nethelper
mlinsemier
Posted in wrong topic.
