ISDN BRI Problem
nmaio
I have an ISDN backup circuit that is down on one side. I have a connection back to the Telco accordng to the NT1 LED and the Telco says they can see my NT1. I also had them come out to check the smartjack just by chance it was something odd. So right now I still do not have connectivity over the ISDN line with Layer 1 Deactivated. I have enabled debugging of events and q921 but the only message I get when I clear the interface and shut/no shut is ISDN BR0: L1 persistent Deactivated. Anybody think this could be a bad card? Any help would be appreciated.
Nick
nmaio
Nevermind thanks anyway...just figured it out.
ahpark78
Can you post your router config here?
And also turn on debug output for q921 to debug the first 2 layers.
