IP identification
sivakondalarao
My WAN link is being over utilized by some IPs. Now I want to find out, which IPs are using more bandwidth. I want to check this from router.
What are the commands useful to me in doing this?
skrao
5 Replies 5
ankurbhasin
Level 9
Level 9
Hi Friend,
You can enable ip accounting on your serial interface for few minutes and later can run a command "sh ip accounting"
The ip accounting command records the number of bytes (IP header and data) and packets switched through the system on a source and destination IP address basis. Only transit IP traffic is measured and only on an outbound basis; traffic generated by the router access server or terminating in this device is not included in the accounting statistics.
Have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tiap_r/apl_i1ht.htm#wp1219240
HTH, if yes please rate the post.
Ankur
I think also using ip cach flow will provide more detailed about the amount of bytes, source & destination port numbers sent in every packet
it can be configured as below
router(config)#int
router(config-if)#ip route-cache flow
Ahmed Hussein
Thanks for your response Ahmed. But you didn't give monitoring command to see statistics.
skrao
Sorry
The command is (show ip cach flow)
Ahmed Hussein
ahmed-hussein
Thanks to rate all postings
Ahmed Hussien
