Cisco 867VAE ADSL
jasoncheng09
I have configured this router many times in AU.  The way I do it is dump a working configuration to the new router, change adsl account settings and router connects.  Now I have an installation in NZ dumped working config, changed user details and PVC settings based on NZ config.  Router won't connect (default route missing).  Authentication passes through, IP Address getting assigned but default route is getting rejected.  When I do a "show interface dialer 1", I see that the interfaces are up and an ip address was assigned to the interface.
Any clue on why is this happening?  Below is the debug message from the router and the router config.  This seems just a simple issue, I'm just at a loss on what it is.
Thanks in advanced.
ADSL Specific ROUTER CONFIG:
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer1
description INTERNET_ACCESS_DIALER
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname user@net.com
ppp chap password 7 xxxxxx
ppp pap sent-username user@net.com password xxxxx
no cdp enable
DEBUG MESSAGE:
cm6300_atmsar_1a_teardown_vc(ATM0): vc:1 vpi:0 vci:100
000052: *Dec  6 14:24:19.279 Auck: ATM0 bcm6300_atmsar_vc_teardown
000053: *Dec  6 14:24:19.279 Auck:  Fill up paramaters for PVC 0/100[1] - Request for CoS 0 PCR 1009 SCR 0 MCR 0 us 1009 sched 0 Available 1009
000054: *Dec  6 14:24:19.279 Auck: ATM0 bcm6300_atmsar_change_connection  1 up 0
000055: *Dec  6 14:24:19.787 Auck: ATM0 VC 0/100 Current Total Active VC Count 0
000056: *Dec  6 14:24:19.787 Auck: ATM(): IP multicast cache invalidated for ATM0
000057: *Dec  6 14:24:19.787 Auck: ATM: PVC removed, ATM0 VCD 1 (0/100)Line 0: xDSL G.994 training
000058: *Dec  6 14:24:20.279 Auck: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
000059: *Dec  6 14:24:20.779 Auck: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
000060: *Dec  6 14:24:20.779 Auck: Vi2 PPP DISC: Authentication configuration changed
000061: *Dec  6 14:24:20.779 Auck: PPP: NET STOP send to AAA.
000062: *Dec  6 14:24:20.779 Auck: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
000063: *Dec  6 14:24:20.779 Auck: Vi2 PPP: Sending cstate DOWN notification
000064: *Dec  6 14:24:20.779 Auck: Di1 Deleted neighbor route from AVL tree: topoid 0, address 222.152.45.33
000065: *Dec  6 14:24:20.779 Auck: Di1 IPCP: Remove route to 222.152.45.33
000066: *Dec  6 14:24:20.783 Auck: Vi2 IPCP: Event[DOWN] State[Open to Starting]
000067: *Dec  6 14:24:20.783 Auck: Vi2 IPCP: Event[CLOSE] State[Starting to Initial]
000068: *Dec  6 14:24:20.783 Auck: Vi2 LCP: Event[DOWN] State[Open to Starting]
000069: *Dec  6 14:24:20.783 Auck: Vi2 PPP: Phase is DOWN
000070: *Dec  6 14:24:20.783 Auck: Vi2 PPP: Processing CstateDown message
000071: *Dec  6 14:24:20.783 Auck: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to downLine 0: ADSL link down
Line 0: ADSL G.992 channel analysis
Line 0: ADSL G.992 started
Line 0: ADSL link up, Path 0, us=1037, ds=13417
000072: *Dec  6 14:25:58.479 Auck: %CONTROLLER-5-UPDOWN: Controller VDSL 0, changed state to up
000073: *Dec  6 14:25:58.479 Auck: ATM0: atmsar_get_plim_info
000074: *Dec  6 14:25:58.479 Auck: ATM0:atmsar_update_plimtype
000075: *Dec  6 14:25:58.479 Auck: ATM0 atmsar_update_us_bandwidth(): upstream bw =1037 Kbps
000076: *Dec  6 14:25:59.819 Auck: (ATM0)1a_enable: delay activation of vcd=1, vc=0x85C9FAC0
000077: *Dec  6 14:25:59.819 Auck: atmsar enable ATM0
000078: *Dec  6 14:25:59.819 Auck: ATM0: atmsar_bringup_interface: Interface and atm_db flags are UP
000079: *Dec  6 14:26:01.819 Auck: %LINK-3-UPDOWN: Interface ATM0, changed state to up
000080: *Dec  6 14:26:01.819 Auck:  bcm6300_atmsar_atm_lineaction(ATM0): state=4
000081: *Dec  6 14:26:01.819 Auck: ATM: Repapulate, ATM0
000082: *Dec  6 14:26:01.819 Auck: ATM: PVC activated, ATM0 VCD 1 (0/100)
000083: *Dec  6 14:26:02.819 Auck: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
000084: *Dec  6 14:26:08.295 Auck: (ATM0): VPI/VCI: 0/100, peak 0, Avg 0, mbs 0
000085: *Dec  6 14:26:08.295 Auck:  Reserved bw for 0/100 Available bw = 1037
000086: *Dec  6 14:26:08.295 Auck: ATM0: atmsar_1a_setup_vc, atm_vc_handle = 0x85C9FAC0
000087: *Dec  6 14:26:08.295 Auck: ATM0 bcm6300_atmsar_vc_setup: vcd 1
000088: *Dec  6 14:26:08.295 Auck:  Fill up paramaters for PVC 0/100[1] - Request for CoS 0 PCR 0 SCR 0 MCR 0 us 1037 sched 0 Available 1037
000089: *Dec  6 14:26:08.295 Auck: ATM0 bcm6300_atmsar_change_connection  1 up 1
000090: *Dec  6 14:26:08.295 Auck:  Total scheduled bandwidth after configuringPVC 0/100 will be 0
000091: *Dec  6 14:26:08.295 Auck: atmsar_setup_cos(ATM0): vc:1 wred_name: max_q:40
000092: *Dec  6 14:26:08.295 Auck: ATM0: VC setup successful (vcd = 1)
000093: *Dec  6 14:26:08.295 Auck: ATM0 Current Active VC count 1
000094: *Dec  6 14:26:08.295 Auck: ATM: PVC activated, ATM0 VCD 1 (0/100)
000095: *Dec  6 14:26:09.219 Auck: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
000096: *Dec  6 14:26:09.219 Auck: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
000097: *Dec  6 14:26:09.219 Auck: Vi2 PPP: Sending cstate UP notification
000098: *Dec  6 14:26:09.219 Auck: Vi2 PPP: Processing CstateUp message
000099: *Dec  6 14:26:09.219 Auck: PPP: Alloc Context [84B5F8DC]
000100: *Dec  6 14:26:09.219 Auck: ppp2 PPP: Phase is ESTABLISHING
000101: *Dec  6 14:26:09.219 Auck: ppp2 PPP: Using AAA Unique Id = F
000102: *Dec  6 14:26:09.219 Auck: Vi2 PPP: Authorization required
000103: *Dec  6 14:26:09.219 Auck: Vi2 PPP: Using dialer call direction
000104: *Dec  6 14:26:09.219 Auck: Vi2 PPP: Treating connection as a callout
000105: *Dec  6 14:26:09.219 Auck: Vi2 PPP: Session handle[6F000002] Session id[2]
000106: *Dec  6 14:26:09.219 Auck: Vi2 LCP: Event[OPEN] State[Initial to Starting]
000107: *Dec  6 14:26:09.219 Auck: Vi2 PPP: No remote authentication for call-out
000108: *Dec  6 14:26:09.219 Auck: Vi2 LCP: O CONFREQ [Starting] id 1 len 10
000109: *Dec  6 14:26:09.219 Auck: Vi2 LCP:    MagicNumber 0x54526845 (0x050654526845)
000110: *Dec  6 14:26:09.219 Auck: Vi2 LCP: Event[UP] State[Starting to REQsent] p 0 len 0 p 0 len 6
000111: *Dec  6 14:26:09.239 Auck: Vi2 LCP: I TERMREQ [REQsent] id 8 len 4
000112: *Dec  6 14:26:09.239 Auck: Vi2 LCP: O TERMACK [REQsent] id 8 len 4
000113: *Dec  6 14:26:09.239 Auck: Vi2 LCP: Event[Receive TermReq] State[REQsent to REQsent]
000114: *Dec  6 14:26:11.235 Auck: Vi2 LCP: O CONFREQ [REQsent] id 2 len 10
000115: *Dec  6 14:26:11.235 Auck: Vi2 LCP:    MagicNumber 0x54526845 (0x050654526845)
000116: *Dec  6 14:26:11.235 Auck: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent] p 0 len 14 p 0 len C
000117: *Dec  6 14:26:11.307 Auck: Vi2 LCP: I CONFREQ [REQsent] id 76 len 18
000118: *Dec  6 14:26:11.307 Auck: Vi2 LCP:    MRU 1500 (0x010405DC)
000119: *Dec  6 14:26:11.307 Auck: Vi2 LCP:    AuthProto PAP (0x0304C023)
000120: *Dec  6 14:26:11.307 Auck: Vi2 LCP:    MagicNumber 0x4CB0264A (0x05064CB0264A)
000121: *Dec  6 14:26:11.307 Auck: Vi2 LCP: O CONFACK [REQsent] id 76 len 18
000122: *Dec  6 14:26:11.307 Auck: Vi2 LCP:    MRU 1500 (0x010405DC)
000123: *Dec  6 14:26:11.307 Auck: Vi2 LCP:    AuthProto PAP (0x0304C023)
000124: *Dec  6 14:26:11.307 Auck: Vi2 LCP:    MagicNumber 0x4CB0264A (0x05064CB0264A)
000125: *Dec  6 14:26:11.307 Auck: Vi2 LCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
000126: *Dec  6 14:26:11.307 Auck: Vi2 LCP: I CONFACK [ACKsent] id 2 len 10
000127: *Dec  6 14:26:11.307 Auck: Vi2 LCP:    MagicNumber 0x54526845 (0x050654526845)
000128: *Dec  6 14:26:11.307 Auck: Vi2 LCP: Event[Receive ConfAck] State[ACKsent to Open]
000129: *Dec  6 14:26:11.331 Auck: Vi2 PPP: No authorization without authentication
000130: *Dec  6 14:26:11.331 Auck: Vi2 PPP: Phase is AUTHENTICATING, by the peer
000131: *Dec  6 14:26:11.331 Auck: Vi2 PAP: Using hostname from interface PAP
000132: *Dec  6 14:26:11.331 Auck: Vi2 PAP: Using password from interface PAP
000133: *Dec  6 14:26:11.331 Auck: Vi2 PAP: O AUTH-REQ id 1 len 40 from "user@net.com"
000134: *Dec  6 14:26:11.331 Auck: Vi2 LCP: State is Open p 0 len F
000135: *Dec  6 14:26:11.347 Auck: Vi2 PAP: I AUTH-ACK id 1 len 13 msg is "Login ok"
000136: *Dec  6 14:26:11.347 Auck: Vi2 PPP: Phase is FORWARDING, Attempting Forward
000137: *Dec  6 14:26:11.351 Auck: Vi2 PPP: Phase is ESTABLISHING, Finish LCP
000138: *Dec  6 14:26:11.351 Auck: Vi2 PPP: Phase is UP
000139: *Dec  6 14:26:11.351 Auck: Vi2 IPCP: Protocol configured, start CP. state[Initial]
000140: *Dec  6 14:26:11.351 Auck: Vi2 IPCP: Event[OPEN] State[Initial to Starting]
000141: *Dec  6 14:26:11.351 Auck: Vi2 IPCP: O CONFREQ [Starting] id 1 len 10
000142: *Dec  6 14:26:11.351 Auck: Vi2 IPCP:    Address 0.0.0.0 (0x030600000000)
000143: *Dec  6 14:26:11.351 Auck: Vi2 IPCP: Event[UP] State[Starting to REQsent]
000144: *Dec  6 14:26:11.355 Auck: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
000145: *Dec  6 14:26:11.355 Auck: ATM: Repapulate, Virtual-Access2  p 0 len C p 0 len C
000146: *Dec  6 14:26:11.459 Auck: Vi2 IPCP: I CONFREQ [REQsent] id 45 len 10
000147: *Dec  6 14:26:11.459 Auck: Vi2 IPCP:    Address 222.152.xxx.xxx (0x0306DE982D21)
000148: *Dec  6 14:26:11.459 Auck: Vi2 IPCP: O CONFACK [REQsent] id 45 len 10
000149: *Dec  6 14:26:11.459 Auck: Vi2 IPCP:    Address 222.152.xxx.xxx(0x0306DE982D21)
000150: *Dec  6 14:26:11.459 Auck: Vi2 IPCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
000151: *Dec  6 14:26:11.459 Auck: Vi2 IPCP: I CONFNAK [ACKsent] id 1 len 10
000152: *Dec  6 14:26:11.459 Auck: Vi2 IPCP:    Address 219.89.xxx.xxx (0x0306DB597BB9)
000153: *Dec  6 14:26:11.459 Auck: Vi2 IPCP: O CONFREQ [ACKsent] id 2 len 10
000154: *Dec  6 14:26:11.459 Auck: Vi2 IPCP:    Address 219.89.xxx.xxx (0x0306DB597BB9)
000155: *Dec  6 14:26:11.459 Auck: Vi2 IPCP: Event[Receive ConfNak/Rej] State[ACKsent to ACKsent] p 0 len C
000156: *Dec  6 14:26:11.479 Auck: Vi2 IPCP: I CONFACK [ACKsent] id 2 len 10
000157: *Dec  6 14:26:11.479 Auck: Vi2 IPCP:    Address 219.89.xxx.xxx (0x0306DB597BB9)
000158: *Dec  6 14:26:11.479 Auck: Vi2 IPCP: Event[Receive ConfAck] State[ACKsent to Open]
000159: *Dec  6 14:26:11.491 Auck: Vi2 IPCP: State is Open
000160: *Dec  6 14:26:11.491 Auck: Di1 IPCP: Install negotiated IP interface address 219.89.123.185
000161: *Dec  6 14:26:11.491 Auck: ATM: Repapulate, Dialer1
000162: *Dec  6 14:26:11.491 Auck: Di1 Added to neighbor route AVL tree: topoid 0, address 222.152.xxx.xxx
000163: *Dec  6 14:26:11.491 Auck: Di1 IPCP: Route not installed to 222.152.xxx.xxx p 0 len E p 0 len E p 0 len E p 0 len E p 0 len E
000164: *Dec  6 14:27:05.931 Auck: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed state to down
000165: *Dec  6 14:27:06.931 Auck: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to down p 0 len E
paolo bevilacqua
int dialer0
ppp ipcp route detault
