Cisco 870 ATM Service-policy problem
ar
Hi Guys.
I encountered this problem with cisco 870 atm interface. I applied service-policy output, its being accepted but when you do a show run interface, it's not there.
is this a bug?
IOS version used is:
c870-advipservicesk9-mz.124-15.T11.bin
5 Replies 5
ar
anyone has experience on this?
Hi Allan,
I can't guarantee I will be able to help as I haven't had much exposure to ATM configuration, but still, I would need to see your configuration including the command you are trying to add, including the result of addition of that command.
Best regards,
Peter
allan,
I hope you have checked the log of the router when you apply this "service-policy" command on the ATM interface. The reason why I say this is because for ATM interface, based on whether the policy has shaping configured or not, we have to use vbr-nrt and then it is accepted
check this Cisco document "Where Do I Apply a QoS Service Policy on an ATM Interface?"
http://www.cisco.com/en/US/tech/tk39/tk824/technologies_tech_note09186a00800d76b5.shtml
Hope it helps
Neeraj
Neeraj,
Good document! Thanks!
Best regards,
Peter
Hi.
Yes i checked the logs.
No errors.
It is actually accepting new policies but not taking effect.
Say example I have the following policy active:
policy-map VOICE-LLQ
class voice
  priority percent 70
class class-default
  random-detect
interface ATM0.1 point-to-point
ip address 10.12.1.150 255.255.255.252
pvc 0/33
  vbr-rt 2048 2048
  encapsulation aal5snap
  service-policy output VOICE-LLQ
This is running already...
I am now trying to modify this to the one below: parent/child policy.
policy-map 2M
class class-default
  shape average 2000000
  service-policy normal-2M
policy-map normal-2M
class voice
  priority percent 70
class application
  bandwidth percent 20
  class class-default
   random-detect
Policy was accepted:
(config)#int atm0.1
(config-subif)#pvc 0/33
(config-if-atm-vc)#ser
(config-if-atm-vc)#service-policy out
(config-if-atm-vc)#service-policy output hwns-2M
(config-if-atm-vc)#
But after checking:
ip mtu 1500
atm route-bridged ip
pvc 0/33
  vbr-rt 2048 2048
Its not there....even with sh policy-map interface command.
I also notice I can always configure back the old policy. But it wont accept any other new policies. Even an identical policy of the first one but with new name.
