cisco 871 games keep dropping or lagging out
tonymlee18
Not sure if this is the right place to put my problem but I have a problem with my cisco router and I have no clue what is causing it. I tried using QoS and the problem still occurs. Any time during a game or streaming video I would lose connection for example in wow I will be able frozen can't cast or do anything. If I'm watching a streaming video it would lose connection.
I had a linksys WRT54G and it would work fine. No disconnects or freezing during gameplay.
Also if i'm using pandora it works fine. When I get a DC or frozen game I can still surf the internet.
here is my config.
darkorb#show run
Building configuration...
Current configuration : 7387 bytes
version 12.4
no service pad
service password-encryption
hostname darkorb
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5
enable password 7
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 syslog
dot11 ssid GuestWLAN
vlan 20
authentication open
authentication key-management wpa
wpa-psk ascii 7
dot11 ssid MyWIFI
vlan 1
authentication open
guest-mode
wpa-psk ascii 7
ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.2.1 192.168.2.99
ip dhcp pool Internal-net
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   domain-name darkorb.local
   lease 4
ip dhcp pool VLAN20
   import all
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   lease 4
ip cef
no ip domain lookup
ip domain name darkorb.local
ip inspect name MYFW appfw MYFW
ip inspect name MYFW tcp
ip inspect name MYFW udp
no ipv6 cef
appfw policy-name MYFW
  application http
    strict-http action allow
    port-misuse tunneling action allow
    port-misuse p2p action reset alarm
    audit-trail on
username admin privilege 15 password 7
archive
log config
  hidekeys
class-map match-any WebEmail
match protocol http
match protocol secure-http
match protocol ftp
match protocol smtp
match protocol pop3
class-map match-any VoIP
match protocol skype
class-map match-any sdm_p2p_kazaa
match protocol fasttrack
match protocol kazaa2
class-map match-any sdm_p2p_edonkey
match protocol edonkey
class-map match-any sdm_p2p_gnutella
match protocol gnutella
class-map match-any sdm_p2p_bittorrent
match protocol bittorrent
class-map match-any counterstrike
match access-group name counterstrike
policy-map sdmappfwp2p_MYFW
class sdm_p2p_edonkey
   drop
class sdm_p2p_gnutella
   drop
class sdm_p2p_kazaa
   drop
class sdm_p2p_bittorrent
   drop
policy-map MyQoSPolicy
   drop
class VoIP
  set dscp ef
    priority percent 25
class counterstrike
    bandwidth remaining percent 40
class WebEmail
    bandwidth remaining percent 35
   drop
   drop
class sdm_p2p_kazaa
   drop
class class-default
    fair-queue
bridge irb
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description Your WAN Interface to the Internet running at 1000
bandwidth 1000
ip address dhcp
ip access-group Internet-inbound-ACL in
ip access-group Internet-outbound-ACL out
ip nbar protocol-discovery
ip nat outside
ip inspect MYFW out
ip virtual-reassembly
ip tcp adjust-mss 1460
load-interval 30
duplex auto
speed auto
no cdp enable
service-policy input sdmappfwp2p_MYFW
interface Dot11Radio0
no ip address
no dot11 extension aironet
encryption vlan 1 mode ciphers tkip
encryption vlan 20 mode ciphers tkip
ssid WTF321
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.20
description Guest wireless LAN - routed WLAN
encapsulation dot1Q 20
ip address 192.168.2.1 255.255.255.0
ip access-group Guest-ACL in
ip nat inside
ip inspect MYFW out
shutdown
service-policy output sdmappfwp2p_MYFW
interface Vlan1
description Internal Network
no ip address
ip nat inside
bridge-group 1
interface BVI1
description Bridge to Internal Network
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip access-list extended Guest-ACL
deny   ip any 192.168.1.0 0.0.0.255
permit ip any any
ip access-list extended Internet-inbound-ACL
permit udp any eq bootps any eq bootpc
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any traceroute
permit gre any any
permit esp any any
ip access-list extended Internet-outbound-ACL
permit ip any any
permit ip 192.168.1.0 0.0.0.55 host 192.168.1.50
ip access-list extended counterstrike
permit tcp any any range 27030 27039
permit tcp any any range 27015 27020
permit udp any any range 27000 27015
permit udp any any range 1119 1120
permit tcp any any range 1119 1120
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
bridge 1 route ip
line con 0
password 7
no modem enable
line aux 0
line vty 0 4
password 7
scheduler max-task-time 5000
end
darkorb#
lgijssel
Level 9
Level 9
Try to remove the following commands from int fa4:
ip inspect MYFW out
Try this both one by one or in any valid combination and see if the problem disappears.
This will lower your security but if one of these is the cause, its the only way to find out.
In general, always triple-check your security settings when something from the Internet is not working.
regards,
Leo
