Cisco 877 router
Oli2ander
I bought a Cisco 877 router with the ADSL-POT interface (not WAN port) and have done the Wizard with all the correct settings... However I cannot seem to get the PPPOE thing to connect. The interface is up but on the Overview its Down... Any suggestions?
whiteford
Can you please post your config?
!version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Oreig
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret xxx
no aaa new-model
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-888454089
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-888454089
revocation-check none
rsakeypair TP-self-signed-888454089
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip bootp server
no ip domain lookup
ip domain name oreig.mine.nu
username Administrator privilege 15 secret xxx
archive
log config
hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
ip nat outside
ip virtual-reassembly
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1412
interface Dialer0
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxx password 7 xxxx
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface ATM0.1 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
It seems to be a cable problem, does anyone have a wireing diagram for the ADSL connection. I have two cord in to the house and into a splitter...
Now i bought another Cisco router (851) and still have the same problem, now got two Cisco ADSL routers that cant connect to the ADSL lines...
Can I set up the old Speedtouch 546i modems in bridged mode and use the Cisco 851 or 877 routers to connect to it from any of the LAN ports meaning not using the ADSL POTS interface (using PPPoE)?
