Cisco 881 router in a subnet
naveen230
I have a cisco 800 series router and its connected to a subnet (10.2.1.XXX local network address) and is connected to the Internet.How can I configure the LAN interfaces(FE0 to FE3) to be able to connect to the internet?Now I'm able to assign a 192.168.X.X address to internal devices connected to router but it isn't connected to Internet!
.Here is the summary of the configurations I did,
interface Vlan1
ip dhcp excluded-address 192.168.1.1 192.168.1.30
ip dhcp pool mypool
  network 192.168.1.0 255.255.255.0
  default-router 192.168.1.1
  dns-server 8.8.8.8
 interface FastEthernet4
ip address dhcp
p nat outside
 no shutdown
The router is picking the address 10.2.1.74(connected to internet) and a host device is having address 192.168.1.31 but it isn't connected to Internet.
Also I tried adding this,
ip nat inside source list 1 fastethernet4 overload
Please provide with a suggestion as I'm new to this!
Naveen
2 Accepted Solutions
here is the config you need (important parts in bold).
The ip dhcp excluded address had a type, make sure it is .168 and not .169.
version 15.5
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$vj0L$Vr9N06SezranvjdQ/gLK/1
no aaa new-model
ethernet lmi ce
ip dhcp pool my pool
dns-server 8.8.8.8 8.8.4.4
lease 3
ip cef
no ipv6 cef
license udi pid C881-K9 sn FJC2210L07Y
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.1.0
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
you mean your computers have IP addresses in the 10.2.x.x range ? Can you at least ping 8.8.8.8 from the router ?
Anything can be routed, but you need a layer 3 interface which is the default gateway for your clients. The network also needs to be added to the access list that is used for NAT, e.g.;
interface VLAN10
ip address 10.2.1.1 255.255.255.0
ip nat inside
access-list 1 permit 10.2.1.0 0.0.0.255
17 Replies 17
Reza Sharifi
Can you post the output of "sh run"?
Building configuration...
Current configuration : 1477 bytes
! Last configuration change at 20:57:12 UTC Tue Apr 3 2018
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip dhcp excluded-address 192.169.1.1 192.169.1.30
dns-server 8.8.8.8
ip cef
no ipv6 cef
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
johnd2310
Level 8
Level 8
What device is connected to interface fa4?
John
**Please rate posts you find helpful**
Fa4 is connected to the internet through a cable
EduardR
I think you almost have everything done... Just some minor tweaks:
You must configure the NAT for the inside interfaces (Fe0 to Fe3)
interface fastethernet 0
  ip nat inside
interface fastethernet 1
  ip nat inside
interface fastethernet 2
  ip nat inside
interface fastethernet 3
  ip nat inside
You define the NAT for the outside interface
interface fastethernet 4
  ip nat outside
Use your nat definition:
ip nat pool NAME 10.2.1.74 10.2.1.74 prefix 24 <--- i think...
Indicate the translation:
ip nat inside source list 1 pool NAME overload
access-list 1 permit 192.168.1.0  0.0.0.255
Also, i think you need a route to the outside... something like:
ip route 0.0.0.0 0.0.0.0 <IP OF THE INTERNET NEXT HOP>
ANd with that i think you can connect your endpoints to the internet.
Thanks for the reply followed your instructions and got
Router(config)#interface FastEthernet0
Router(config-if)#ip nat inside
% Invalid input detected at '^' marker.
naveen230
Hello everyone,
thanks for the reply guys,
here 10.2.1.74 is the address assigned for FA4(WAN) USING DHCP.Just to be clear!
and I want the other interfaces(FE0 to FE3) to have the same IP 10.2.X.X and connected to internet as well(like a switch)!
Is is possible?
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
lease 3
ip cef
no ipv6 cef
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Thanks for the suggestion,
I followed the instructions but still devices connected to FE0-FE3 not connected to Internet.Is it because the router is connected to private network(10.2..x.x addresses) and its not possible to route? (asked in other forums)
N
interface VLAN10
ip nat inside
All devices connected to internet have 10.2.x.x address because its a private network.And i'm able to ping 8.8.8.8 on the router and its successful.But on the device connected to router through FE0 to FE3 not able to ping google.com.
yes 10.2.1.1 is the default gateway for the clients.
Hi Naveen,
1) Did the devices connected to interface fa0 - fa3 receive IP addresses from the DHCP pool (192.168.1.x)?
2) If yes, could you ping 192.168.1.1 from those devices? How about 10.2.1.1?
3) If no, please post the output of "show vlan-switch brief". If you made many changes, please post "sh run" as well.
HTH,
Meheretab
HTH,
Meheretab
10.2.1.1 is the gateway already used Can I use the same for this router bacause
FE4 has IP address 10.2.1.74
and when I configure
interface Vlan1
I get IP address conflicts!
