Cisco 881 router in a subnet
naveen230
I have a cisco 800 series router and its connected to a subnet (10.2.1.XXX local network address) and is connected to the Internet.How can I configure the LAN interfaces(FE0 to FE3) to be able to connect to the internet?Now I'm able to assign a 192.168.X.X address to internal devices connected to router but it isn't connected to Internet!
.Here is the summary of the configurations I did,
interface Vlan1
ip dhcp excluded-address 192.168.1.1 192.168.1.30
ip dhcp pool mypool
  network 192.168.1.0 255.255.255.0
  default-router 192.168.1.1
  dns-server 8.8.8.8
 interface FastEthernet4
ip address dhcp
p nat outside
 no shutdown
The router is picking the address 10.2.1.74(connected to internet) and a host device is having address 192.168.1.31 but it isn't connected to Internet.
Also I tried adding this,
ip nat inside source list 1 fastethernet4 overload
Please provide with a suggestion as I'm new to this!
Naveen
17 Replies 17
FastEthernet4 is the WAN interface. What is connected to this interface, another modem/router ?
Please find beneath my suggestion of your router configuration. I took your original configuration as the starting point and all changes/additions are marked as bold:
version 15.5
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$vj0L$Vr9N06SezranvjdQ/gLK/1
no aaa new-model
ethernet lmi ce
ip dhcp pool my pool
 dns-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid C881-K9 sn FJC2210L07Y
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 10.2.1.1
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input none
scheduler allocate 20000 1000
end
Best regards,
Antonin
Hello the following configuration worked for me.Thanks for the support you guys.
Router#sh run
Building configuration...
Current configuration : 1557 bytes
! Last configuration change at 15:10:48 UTC Wed Apr 4 2018
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip dhcp excluded-address 10.2.2.1 10.2.2.30
ip dhcp pool mypool
network 10.2.2.0 255.255.255.0
default-router 10.2.2.1
dns-server 8.8.8.8 8.8.4.4 10.2.1.44
ip cef
no ipv6 cef
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip address 10.2.2.1 255.255.255.0
ip nat inside
no ip http server
ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
access-list 1 permit 10.2.2.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
