Cisco 886 pppoe with bridged modem
ganick
Need some help on setting up a remote site which used to be like below (an ISDN line plugged directly into Cisco 886):
Existing Topology
LAN(VLAN1) <---> (VLAN1)(FE0) Cisco 886 (ATM0) <---> OTE (ISP)
and it will be migrated to this (a VoBB line plugged into ISPs bridged router and connected to Cisco 886 FE):
New Topology
LAN(VLAN1) <---> (VLAN1)(FE0) Cisco 886 (FE1)(VLAN2) <---> OTE Router (Bridge Mode) <---> OTE (ISP)
First things first, the Cisco 886 has an old IoS v12.4, how can I check that the new topology is even possible
(PPPoE over FE interface) ?
I'll post the old (working) and the new (proposed) config for the Cisco, please advise!
Thx in advance,
Nikos
The old config is this:
Remote Site
Existing Topology
Config
version 12.4
no service pad
service password-encryption
no service dhcp
hostname dad-po
boot-start-marker
boot system flash c880data-universalk9-mz.124-22.YB6.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.4.1 192.168.4.33
ip dhcp pool opap-pool
network 192.168.4.0 255.255.255.0
dns-server 195.170.0.1 195.170.2.2
default-router 192.168.4.1
lease 2
ip cef
ip domain name dad.local
ip name-server 195.170.0.1
ip name-server 195.170.2.2
ip name-server 192.168.1.26
no ipv6 cef
username admin privilege 15 password xxxxx
crypto isakmp policy 1
authentication pre-share
crypto isakmp key ******** address 79.129.55.1
crypto isakmp key ******** address 79.129.19.97
crypto ipsec transform-set dad esp-des esp-md5-hmac
crypto map vpn1 10 ipsec-isakmp
set peer 79.129.19.97
set transform-set dad
match address 131
archive
log config
hidekeys
interface Tunnel0
ip address 192.168.222.2 255.255.255.0
ip mtu 1476
tunnel source Dialer0
tunnel destination 79.129.19.97
tunnel key 1324
crypto map vpn1
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
no atm ilmi-keepalive
interface ATM0.1 point-to-point
no ip route-cache
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.4.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxx@otenet.gr
ppp chap password xxxxxx
ppp pap sent-username xxxxxx@otenet.gr password xxxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 192.168.1.0 255.255.255.0 192.168.222.1
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer0 overload
access-list 23 permit 79.129.7.156
access-list 23 permit 195.97.104.72
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 23 permit 192.168.4.0 0.0.0.255
access-list 23 permit 192.168.222.0 0.0.0.255
access-list 100 permit ip 192.168.4.0 0.0.0.255 any
access-list 130 permit gre host 79.129.46.143 host 79.129.55.1
access-list 131 permit gre host 79.129.46.143 host 79.129.19.97
snmp-server community private RW
snmp-server community public RO
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
login local
scheduler max-task-time 5000
end
New Topology
Config
version 12.4
no service pad
hostname dad-po-c886
boot-start-marker
boot-end-marker
logging buffered 64000
logging rate-limit 20
logging console informational
enable secret 5 $1$GyvL$3/N07Kd1aBF8SfT.Gub6W0
no aaa new-model
clock timezone UTC 3
ip source-route
lease 2
ip cef
no ip domain lookup
no ipv6 cef
username admin privilege 15 secret 5 $1$WTJA$z2u0ss2aBi2Ex8N/BP57M0
username officeln privilege 15 secret 5 $1$W181$ykyTqBrVmYoiRa.Z/Lfqz/
match address 131
archive
log config
hidekeys
interface Tunnel0
ip mtu 1476
tunnel key 1324
crypto map vpn1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
shutdown
description === WAN OTE ===
switchport access vlan 2
interface Vlan1
description === Connected to LAN ===
ip nat inside
interface Vlan2
description === WAN xDSL OTE1 ====
pppoe enable group global
interface Dialer0
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
no ip http server
access-list 23 permit 79.107.178.160
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
logging synchronous
login local
transport input telnet ssh
ntp server 194.116.168.40
end
I don't think you can use any of the FE interfaces on the 886 for PPPoE, the 886 is ADSL/VDSL only. These are layer 2 switchports only.
In interface configuration mode, check if anything starting with 'pppoe' is available at all, I don't believe it is...
What are my alternatives ?... Which Cisco routers for Small Business support the new topology ?
any of the 800 series with Ethernet in the First Mile (EFM) support will do e.g. the 888E):
https://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
