Cisco 887 (3G) routing from LAN being blocked?
johnelliot6
Level 2
Level 2
Weird issue with an 887 connecting via Dialer to 3G(We run LNS the router is terminating on(7200)) - From 7200, can ping WAN IP assigned to 3G dialer:
ping vrf HOCA 172.18.35.2
Sending 5, 100-byte ICMP Echos to 172.18.35.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 80/83/96 ms
From CE can ping 7200 loop:
#ping 172.18.35.1
Sending 5, 100-byte ICMP Echos to 172.18.35.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 80/318/1212 ms
CE has default route of dialer:
#sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
  Known via "static", distance 1, metric 0 (connected), candidate default path
  Routing Descriptor Blocks:
  * directly connected, via Dialer2
      Route metric is 0, traffic share count is 1
7200 has route for CEs LAN (192.168.130.0/24):
>sh ip route vrf HOCA 192.168.130.0
Routing entry for 192.168.130.0/24
  Redistributing via bgp 17766
  Advertised by bgp 17766
  * 172.18.35.2
But cannot ping lan IP of CE:
>ping vrf HOCA 192.168.130.1
Sending 5, 100-byte ICMP Echos to 192.168.130.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
vlan is definitely up on CE:
#sh int vlan 1
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 1cdf.0f12.ddae (bia 1cdf.0f12.ddae)
  Description: EHOCA_3G_LAN
  Internet address is 192.168.130.1/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not supported
If I debug icmp, I am seeing unusual output(In that I have never seen "topology BASE, dscp 0 topoid 0" etc)
icmp that is working seems to be marked as dscp 10, where the icmp that isn't working is marked as dscp 0(probably coincidence)
*Feb  2 05:13:06.251: ICMP: echo reply rcvd, src 172.18.35.1, dst 172.18.35.2, topology BASE, dscp 10 topoid 0
*Feb  2 05:13:06.291: ICMP: echo reply rcvd, src 172.18.35.1, dst 172.18.35.2, topology BASE, dscp 10 topoid 0
*Feb  2 05:13:06.991: ICMP: echo reply rcvd, src 172.18.35.1, dst 172.18.35.2, topology BASE, dscp 10 topoid 0
*Feb  2 05:13:07.291: ICMP: echo reply rcvd, src 172.18.35.1, dst 172.18.35.2, topology BASE, dscp 10 topoid 0
*Feb  2 05:13:07.531: ICMP: echo reply rcvd, src 172.18.35.1, dst 172.18.35.2, topology BASE, dscp 10 topoid 0
*Feb  2 05:13:22.563: ICMP: echo reply sent, src 192.168.130.1, dst 172.18.35.1, topology BASE, dscp 0 topoid 0
*Feb  2 05:13:24.567: ICMP: echo reply sent, src 192.168.130.1, dst 172.18.35.1, topology BASE, dscp 0 topoid 0
*Feb  2 05:13:26.551: ICMP: echo reply sent, src 192.168.130.1, dst 172.18.35.1, topology BASE, dscp 0 topoid 0
*Feb  2 05:13:28.551: ICMP: echo reply sent, src 192.168.130.1, dst 172.18.35.1, topology BASE, dscp 0 topoid 0
*Feb  2 05:13:30.551: ICMP: echo reply sent, src 192.168.130.1, dst 172.18.35.1, topology BASE, dscp 0 topoid 0
IOS is c880data-universalk9-mz.151-1.T1.bin
CE config is one we use for all vrf CE's (no nat, no acl's - very simple config), and the 7200(LNS) has 00's of DSL tails terminating on it that work without issue.
Any suggestions are greatly appreciated.
johnelliot6
Level 2
Level 2
Found out it is the 3G supplier that is blocking routed subnets - Any suggestions on a work-around(Potentially use a tunnel to route the additional subnet?)
