cisco 887v vdsl is not showing atm interface
j.medinapadilla
Async1                     unassigned      YES NVRAM  down                  down
BRI0                         unassigned      YES NVRAM  administratively down down
BRI0:1                      unassigned      YES unset  administratively down down
BRI0:2                      unassigned      YES unset  administratively down down
Ethernet0                  unassigned      YES NVRAM  administratively down down
FastEthernet0            unassigned      YES unset  up                    down
FastEthernet1            unassigned      YES unset  up                    down
FastEthernet2            unassigned      YES unset  up                    down
FastEthernet3            unassigned      YES unset  up                    down
Vlan1                      192.168.1.1     YES NVRAM  up                    down
Router#
System image file is "flash:c880data-universalk9-mz.151-3.T.bin"
see is not showing the atm interface please guys give me a hand with this issue
Best Regards
11 Replies 11
paolo bevilacqua
You need to configure mode under controller vdsl0 first.
Note 887V is VDSL2 only and does not supports ADSL.
yes i did it but it just have operating mode auto and for vdsl2 doesn't sopport any command
I believe VDSL is configured under Ethernet0 in this model and there is no ATM interface.
See http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/routconf.html#wp1163169
That is correct, no ATM and no ADSL on 877V-xx
Ok i undertand that but why does the router have a VDSL o POTS PORT ?
Network / Transport ProtocolL2TP, IPSec, PPPoE, PPPoA, FTP, DHCP, DNS, L2TPv3, DDNSRAM256 MB (installed) / 768 MB (max)Remote Management ProtocolTelnet, SNMP 3, HTTP, HTTPS, SSHRouting ProtocolOSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, PIM-SM, GREStatus IndicatorsPort status, powerCommunicationsDigital Signaling Protocol VDSL2
TypeISDN / DSL modem comboEnvironmental ParametersHumidity Range Operating10 - 85% (non-condensing)Max Operating Temperature104 °FMin Operating Temperature32 °FExpansion / ConnectivityInterfacesLAN : 4 x 10Base-T/100Base-TX - RJ-45 ¦ Management : 1 x RJ-45 ¦ WAN : 1 x VDSL2 ¦ USB : 1 x 4 pin USB Type A ¦ WAN : 1 x BRI ST
VDSL2 uses PTM (packet transfer mode), not ATM. That's how it works.
I have an 867VAE working here, VDSL2 over POTS. No ATM involved.
Also see http://www.cisco.com/en/US/prod/collateral/routers/ps380/qa_c67_458826.html
Q. Does the Cisco 887V platform also support ADSL, ADSL2, and ADSL2+?
A. The Cisco 887V platform supports only VDSL2 technology.
Q. Does the Cisco 887V platform support both ATM and Ethernet Packet Transport Mode (PTM)?
A. The platform supports only PTM.
you need to connect the cable there.
for VDSL tech , you don´t have an ATM interface. you need to configure it via ethernet int over ppoe. It is quite tricky I know it. If you have any question I can share a cisco config-
thanks
Jesus
Please do share the configuariton, i believe the copper cable from ISP will conenct to VDSLoPots and we will configure ethernet with "pppoe-client dial-pool-number 1" and then configure the respective dialer interface?
But would it get all the parameters like PVC/VCI numbers automatically?
thanks.
Zee
Again: there is not ATM, and no VPI/VCI in VDSL2.
for VDSL PCV/VCI  and ATM are not required,
attached, is cisco config.
bassically :
interface Ethernet0
description $ETH-WAN$
no ip address
no fair-queue
interface Dialer0
ip address negotiated
ip access-group 100 in
ip mtu 1492
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username adslppp@telefonicanetpa password 0 adslppp
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 ip nat inside source list 1 interface Dialer0 overload
hope this help!!!
