Why i set 4.2.2.2 inside my pc then could surf internet?
phuayhow01
Hi all,
     My PC is accessing the internet via a router. I have been configuring the router in order for my pc to gain access to the internet.
     My issue is that i need to input the 4.2.2.2 inside the "preferred DNS Server" option of my laptop in order to surf the internet. Once i removed this 4.2.2.2 from the "preferred DNS Server" option, my laptop could not surf the internet even i could ping 8.8.8.8 from my laptop.
     Could i know what went wrong as i don't intend to input 4.2.2.2 in every laptop when they are accessing the internet via this router?
     Is there any way to resolve this issue?
Regards.
Raymond
2 Accepted Solutions
johnlloyd_13
Level 9
Level 9
hi raymond,
you'll need to use a DHCP service, either on the router or use a dedicated server, to lessen your admin burden.
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfdhcp.html
saurav.khanna
Hi Raymond,
You need to add DNS settings on the DHCP server which is most probably your router. 4.2.2.2 is a DNS server and your laptop uses it to resolve any site that you are trying to browse via your Laptop. As given in the link just add:
Router(dhcp-config)# dns-server address  [
address2
... address8]
to your DHCp configuration on the router and things will work.
johnlloyd_13
Level 9
Level 9
hi raymond,
saurav.khanna
Hi Raymond,
address2
... address8]
