cisco 887va router config
dparker127
Hi there,
I am trying to configure a Cisco 887va router, initially I am trying to get it to route between my adsl connection (ppp over ATM) and my Ethernet lan (only the one default vlan to start with).
Here is my running config:
EVC_R1#sh running-config
Building configuration...
Current configuration : 1965 bytes
! Last configuration change at 14:32:46 UTC Wed Jun 11 2014
version 15.2
no service pad
hostname EVC_R1
boot-start-marker
boot-end-marker
enable secret 4 PoXaLzKVosUFI2FS5/CPK/sLYb1wgi0LIF6SRnWhVa2
no aaa new-model
memory-size iomem 10
ip domain name emmaus.local
ip cef
no ipv6 cef
password encryption aes
license udi pid CISCO887VA-K9 sn FCZ1733C2CL
username xxx password 0 xxx
controller VDSL 0
ip ssh version 1
interface Ethernet0
 ip address 192.168.52.254 255.255.255.0
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 atm vc-per-vp 128
 no atm ilmi-keepalive
 hold-queue 224 in
 pvc 0/38
  oam-pvc 0
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
 switchport mode trunk
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Vlan1
 no ip address
interface Dialer0
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname xxx@plusdsl.net
 ppp chap password 0 xxx
 ppp pap sent-username xxx@plusdsl.net password 0 xxx
 ppp ipcp dns request
 ppp ipcp wins request
 hold-queue 224 in
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.52.0 0.0.0.255
line con 0
 password $upp0rt100
 login
 no modem enable
line aux 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
First off I am aware that the fastethernet interfaces are layer 2 ports on an integrated switch. I assume that ethernet0 should be treated as an actual router port. It seems to support subinterfaces eg ethernet0.1. So what I had envisaged was using fa0/0 as a trunk port and eventually adding vlan router addresses to subinterfaces of ethernet0.
At present my dialer0 interface acquires the correcty ip address from my isp but pings  fail to hosts in both my local network 192.168.52.0/24 and to internet hosts. Can anyone look at my config and advise?
thanks very much
Dan
17 Replies 17
Hi Dan ,
 Connect your LAN Cable on your router Ethernet port  . You Should able to ping your Local Network 192.168.52.0/24 , Similarly when you create sub interface on your router , switch port  of layer 2/layer 3 switch connecting to your router must be trunk port , not your router port .
Router port must be configured for dot1q encapsulation not as trunk port .
Look into below url for more understanding
http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/14976-50.html
Sandy
kcnajaf
Level 7
Level 7
Hi Dan,
Please modify the configurations as below.
config terminal
int Ethernet 0
no  ip address 192.168.52.254 255.255.255.0
int vlan 1
ip nat inside
ip route 0.0.0.0 0.0.0.0 dialer0
ip classless
Hope that helps.
Najaf
Thanks Najaf, you changes have improved things however i'm not quite there yet. With your changes I can ping external ip addresses successfully (not hostnames although messages show that the router has acquired dns server addresses from my isp) but other than the router's own ip (192.168.52.254) nothing on the internal lan responds to pings.
A show ip nat translations command reveals that no nat translations are occurring and internal hosts can not access the internet.
At present running config reads as:
Current configuration : 2039 bytes
! Last configuration change at 19:09:24 UTC Wed Jun 11 2014
version 15.2
no service pad
hostname EVC_R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
controller VDSL 0
ip ssh version 1
interface Ethernet0
 no ip address
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 atm vc-per-vp 128
 hold-queue 224 in
 pvc 0/38
  oam-pvc 0
 no ip address
 no ip address
 no ip address
 no ip address
interface Vlan1
 ip nat inside
interface Dialer0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 hold-queue 224 in
no ip http server
ip route 0.0.0.0 0.0.0.0 Dialer0
line con 0
 password xxx
 login
 no modem enable
line aux 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
Can anyone help further?
Hi Dan,
Good to know that there is some improvement :-)
How is LAN devices connected to this router? Is this trough a switch? If it through switch do you have any VLANs configured on the switch? Also which interface on the router you are connecting the LAN device?
For testing you can connect a single machine to Fastethernet3 and check if NAT transaction is working fine.
With regards to Hostname not getting resolved try using a public DNS manually (4.2.2.2) rather than ISP DNS and check if things are improving.
Najaf
eaglemobiles1
We have brand new cisco 887va- M router its not been configure can any one help us to povide remote support to configure this router. We would like to use this router for internet use and SIP trunks some kind of sip policy need to be create to prioritise sip traffic.
Any help will be greatly appreciated.
Akbar
Hi Akbar,
        Share me your new device configuration .let me help you with device configuration
Sandy
Hi Sandy,
Many thanks for reply, as I said this is brand new router unconfigured so there isnt any config we will nedd your help to configure from the scratch.
Akbar
Share me show version and show running for your new brand new router . share me topology diagram if you have any .
Need to know about LAN IP address segment and other things
Sandy
Hi Sandy,
our lan details
enable
conf t
parser config cache interface
no service pad
errdisable detect cause all
errdisable recovery cause all
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname COMMSSOURCE
logging buffered 999999
enable secret {a&C}uat69!
no aaa new-model
vtp domain cisco
vtp mode transparent
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
ip cef
ip name-server 8.8.8.8
ip dns server
username commssource secret commssource
username commssource priv 15
interface ATM0
 no ip address
 pvc 0/38
  protocol ppp dialer
  no shut
 spanning-tree portfast
Interface Vlan1
 ip address 10.10.14.1 255.255.255.0
 ip nat inside
NO SHUT
controller vdsl 0
sra
ip dhcp excluded-address 10.1010.1 10.10.141.9
ip dhcp pool vlan1
network 10.10.14.0 255.255.255.0
default-router 10.10.14.1
dns-server 8.8.8.8 8.8.4.4
domain dot.akbar
!option 176 ascii "MCIPADD=10.149.14.50,TFTPSRVR=10.149.14.137"
interface Dialer1
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap callin
 ppp chap hostname <our_isp_username>
 ppp chap password our_isp_password
 no shut
ip nat inside source list 110 interface dialer 1 overload
no ip http server
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 1 permit 192.168.0.0 0.0.255.255
dialer-list 1 protocol ip permit
access-list 110 deny   ip 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
access-list 110 deny   ip 10.0.0.0 0.255.255.255 192.168.0.0 0.0.255.255
access-list 110 deny   ip 10.0.0.0 0.255.255.255 172.16.0.0 0.15.255.255
access-list 110 deny   ip 192.168.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 110 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 110 deny   ip 192.168.0.0 0.0.255.255 172.16.0.0 0.15.255.255
access-list 110 deny   ip 172.16.0.0 0.15.255.255 10.0.0.0 0.255.255.255
access-list 110 deny   ip 172.16.0.0 0.15.255.255 192.168.0.0 0.0.255.255
access-list 110 deny   ip 172.16.0.0 0.15.255.255 172.16.0.0 0.15.255.255
access-list 110 permit ip any any
snmp-server community public RO 1
snmp-server ifindex persist
snmp-server enable traps tty
snmp-server host 10.200.200.200 version 2c public
interface Ethernet0
 no ip address
 NO SHUT
interface Ethernet0.101
 encapsulation dot1Q 101
 pppoe-client dial-pool-number 1
ip ssh version 2
ip ssh time-out 120
line con 0
 no modem enable
line aux 0
line vty 0 4
 password cisco
 login local
 transport input telnet ssh
 ip access-class 1 in
wr
exit
exit
wr
we can connect to VDSL but cant visit websites NAT issue.
what we want is
1- setup this router with lan details above
2- Cretae Vlan1 for Data
3- Vlan2 for Voice
4- QoS for SIP trunks
5- Firewall for our internal network
Akbar
Please can any one help in this issue we urgently need this router to be configureed.
Many thanks
Akbar
Hi Akbar,
 Kindly let me know , where you have got stuck ?
Sandy
Hi Sandy,
As I replied to your previous post you were asking for our lan details i will repeat the issue again.
This is a brand new router unconfigured we need some one to configure it from scartch the configuration we need are below.
what we want is
1- setup this router with lan details (Rourer 10.10.14.1 255.255.255.0) DHCP 10.10.14.10 )
3- Vlan2 for Voice
Akbar
what a useless forum :(
Hi Akbar ,
 Kindly open a webex session or schedule a time slot for supporting you on this .
Sandy
