Bookmark
Subscribe
8511
cisco 887va router config
dparker127
Hi there,
I am trying to configure a Cisco 887va router, initially I am trying to get it to route between my adsl connection (ppp over ATM) and my Ethernet lan (only the one default vlan to start with).
Here is my running config:
EVC_R1#sh running-config
Building configuration...
Current configuration : 1965 bytes
! Last configuration change at 14:32:46 UTC Wed Jun 11 2014
version 15.2
no service pad
hostname EVC_R1
boot-start-marker
boot-end-marker
enable secret 4 PoXaLzKVosUFI2FS5/CPK/sLYb1wgi0LIF6SRnWhVa2
no aaa new-model
memory-size iomem 10
ip domain name emmaus.local
ip cef
no ipv6 cef
password encryption aes
license udi pid CISCO887VA-K9 sn FCZ1733C2CL
username xxx password 0 xxx
controller VDSL 0
ip ssh version 1
interface Ethernet0
 ip address 192.168.52.254 255.255.255.0
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 atm vc-per-vp 128
 no atm ilmi-keepalive
 hold-queue 224 in
 pvc 0/38
  oam-pvc 0
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
 switchport mode trunk
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Vlan1
 no ip address
interface Dialer0
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname xxx@plusdsl.net
 ppp chap password 0 xxx
 ppp pap sent-username xxx@plusdsl.net password 0 xxx
 ppp ipcp dns request
 ppp ipcp wins request
 hold-queue 224 in
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.52.0 0.0.0.255
line con 0
 password $upp0rt100
 login
 no modem enable
line aux 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
First off I am aware that the fastethernet interfaces are layer 2 ports on an integrated switch. I assume that ethernet0 should be treated as an actual router port. It seems to support subinterfaces eg ethernet0.1. So what I had envisaged was using fa0/0 as a trunk port and eventually adding vlan router addresses to subinterfaces of ethernet0.
At present my dialer0 interface acquires the correcty ip address from my isp but pings  fail to hosts in both my local network 192.168.52.0/24 and to internet hosts. Can anyone look at my config and advise?
thanks very much
Dan
17 Replies 17
Hi Sandy,
Thanks for helping, please can you advise how to open a webex session, i am available tomorrow (21/08/2014) 10am to 5pm UK time please advise when you be availabe to help in this issue.
Many thanks
Akbar
Hi ,
 Open a free webex account and share me meeting invite to my contact ID given on my profile
 http://www.webex.com/
Sandy
Hi Sandy,
I have sent you request for meeting but i think you are not avilable, please we availabe send me email to info@commssource.co.uk to reschedule the meeting.
Many thanks
Akbar
