Is this possible without PBR - Routing from Specific Host to Any
GRANT3779
I have an issue where I don't currently have PBR options on my core switch. Now I know I can amend the SDM template and enable the routing one then reboot (I'm also runing ipservices). At the moment though this is not an option.
I have a host - 10.44.129.34 /24 which is a VM.
Current Gateway is 10.44.129.1 which is SVI on our Core.
On the Core I'm looking to say -  anything from this specific host going to any remote network - use gateway 10.44.157.6. Is there a way for me to achieve this without PBR?
I cannot amend the IP of the host IP either due to licensing issues with the software I can;t think of a way to do this without PBR.
Richard Burts
You can identify the traffic with an extended access list. But I can not think of anything you could do with that to achieve your objective other than PBR.
Rick
Rick
