10-20-2021 07:51 AM
hi i need help to configure openvpn server bheind a c887vag-4g
my wan is on LTE 4G interface the openvpn server is on internal lan 10.10.x,x default gw for internal lan is 10.10.x.1
LTE interface have a static public ip A.B.C.D
many thanks for the help.
10-20-2021 07:59 AM
Atached some example guide to start with :
10-20-2021 08:18 AM
thankyou for the reply BB
i think that i have not explained very weel wath i need to do.
i need to publish openvpn server (inside lan) via 4G LTE interface.
the interface works fine i'm in trouble with the nat configuration.
inside server ip is 10.10.x.10 default gw 10.10.x.1
wan interface is Cellular0 with a.b.c.d public ip
wath is the correct nat?
10-20-2021 08:28 AM - edited 10-20-2021 08:32 AM
Ok no problem, post the current config ( show run)
as my understanding
remote users-----(internet cloud)------Provide( your LTE Router) ---(Open VPN Server)
You need NAT in router and ACL for the required ports example : open up ports TCP 443, 943 and UDP 1194
Example NAT :
ip nat inside source static 10.10.x.x A.B.C.D
10-20-2021 08:37 AM
Hi BB
you understand correct.
Friday i'm on router and i can send you the sh run command
regards
10-22-2021 04:37 AM
