cisco 891 interface routing
galaxy1983
Hi all..
I'm having some trouble configuring porting between interfaces.
Here is my situation.
I have a Cisco 891 router. What I need is to create 3 interfaces with the next IPs:
1.  Port FastEthernet 8 - 20.40.1.1 - with a modem connected directly to it - 20.40.1.2
2.  Port GigabitEthernet 0 - 193.2.5.100 - connected to a switch - LAN
3.  Ports FastEthernet 0 and 1 for two VOIP phones - 190.168.5.2 and 190.168.5.3 - will be switchported to VLAN 10 - 190.168.5.1
I can send ping from a PC (193.2.5.1) to the modem interface (20.40.1.1) but not to the modem itself (20.40.1.2).
I played days with configurations and tried a lot of variation of ip routing and access-lists with no success.
Basically I need to comunicate freely betwin all the devices.
There are a lot of forums providing solutions to a same problems but they seems not working with the 891 router.
Can anyone show me the way, assuming I have a factory resetted router?
Edit:
Here my configurations:
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
ip address 20.40.1.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0
ip address 193.2.5.100 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp profile default
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
transport input all
end
Message was edited by: galaxy1983
9 Replies 9
paolo bevilacqua
You need to set an address to VLAN 1.
Why would I need to do that?
Because it's needed.
What's needed is an explanation.
SOcchiogrosso
Level 4
Level 4
Does the modem have a route back to your network?
Sent from Cisco Technical Support Android App
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
Yes
Sam Smiley
Level 3
Level 3
I am not familiar with the 891 that you show here; however it is common practice on the lower end routers that all of the faX ports are switchports, not L3 ports. As mentioned before you will need to add a VLAN1 address; this will assign a network to FastErthernet0 - 8. If by some chance this router does support L3 ports you will be able to issue a "no switchport" command on the interface to turn it into a L3 port prior to assigning the IP address.
These routers are designed for two destinct networks, gi0 (WAN) and VLAN1 (LAN). You can not add a 3rd routed interface to them. In order for the is work you would need to move to a modular router.
Cheers,
Sam
Alex Pfeil
Level 7
Level 7
Did you account for 193.2.5.100 being a public IP address? You should use private IP addresses for local LAN.
Please mark helpful posts.
Alex Pfeil
Level 7
Level 7
You need to configure NAT on the outside and inside interfaces. You can then use your public IP address and port-address translation out to the internet.
outside interface command
ip nat outside
inside interface command
ip nat inside
Create an ACL to match traffic.
access-list 1 permit any
Associate the ACL to the NAT
ip nat inside source list 1 interface "interface" overload
In you configuration above, fastethernet 8 is the port.
You would then need to have a default static route out to the internet.
ip route 0.0.0.0 0.0.0.0 20.40.1.2
