cisco 892 how to connect to my isp modem DHCP connected to ge 0/0
rdenheijer
hi all i need some pointer in what i do wrong
i connected my modem ISP to ge0/0 and gets an dhcp ip so far so good
but when i connect an cable to one of the open fasstethernet nothing happends and yes i am an beginner tryed to add vlans but wont connect
my isp is 192.168.2.1 i added the modem ip dhcp and made an dhcp but when i want to connect to the ge port well nothing
i am doing something very wrong and yes i am an beginner
also 1 port is dedecated 10.10.10.0 well so far i can l can log in to the gui
but then
what i want him to do is allowing the isp dhcp to give fastethernets also an ip adres so i can go on the internet if i try to do the and point to dhcp well you geussed it the router doesnt want to do that
so how can i this beutifull machine talking to the ge0/0
anyone would have the time to tell me how this can be fixed would be greatfull
thank you in advance
2 Accepted Solutions
If the WAN Interface is 1GB interface and you connected to ISP 1GB that is ok ?
if the Lan interfce fast ethernet, that is limitation max 100MB,
if you looking 1GB on the Lan side you need to buy different model which has gig ethernet lan side also.
if that answer all your questions, not further assistance required, can we mark as resolved..so in the future if some one has same issue the users can be refer this thread for solution.
BB
If the WAN Interface is 1GB interface and you connected to ISP 1GB that is ok ? as well as my ISP is 1gb and the gbe0/0 is 1 gb
if the Lan interfce fast ethernet, that is limitation max 100MB, thats to bad
balaji.bandi
Login to command level and post
show run
Thinking that you have connected your ISP side modem Ethernet connection to Gig 0 - below config should work. :
ip dhcp excluded-address 10.10.10.1 10.10.10.5
ip dhcp pool MYDHCP
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 8.8.8.8
interface GigabitEthernet0
ip address dhcp
ip nat outside
no shut
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip routing
access-list 10 permit 10.10.10.0 0.0.0.255
ip nat inside source list 10 interface gig0 overload
ip route 0.0.0.0 0.0.0.0 gig0 dhcp
still not working post new config
show run
show IP interface brief
show IP route
BB
Well thank yo uso much
It works however i had to make an adjustment bcos some fastethernet port wasnt on
Does it works and i can get internet my last qeustion is the speed i run currently on 100 mbit but can ita lso be 1gb and how to do that ?
For the rest thank yo uso much fort his solution i am very greatfull
Cant thank you enoufgh
To clearyfi it has fe0/0 and ge0/0 my isp runs on ge0/0 all of my fastethernets from 0 to 8 runs now on 100 mb but the ge is 1gb is this also configureable?
BB
